78SC Testing / Replacing vacuum advance
Is there a good article or thread that tells how to test and/or replace the vacuum advance unit?
If broken, it would be nice to fix it rather than buy a new one. Can that be done? |
Razor,
I'm in the process of doing the same thing. It should be straight forward with the dist off the motor. There are a couple of Pelican tech articles that I printed (with pictures). I also did a search, but I'm at work now and the links are at home for the discussions that are good for us. The new vacuum unit is only about $22 from Wayne. I'm going to order on and replace it this week. I'll check tonight for you. Souk H |
| All times are GMT -8. The time now is 05:03 PM. |
