That, and I think the passenger's side is a touch lower than the driver's. The car pulls to the right now. Not 'hard', but 'quickly'. I can easily hold it straight with one finger, but it's definitely pronounced with no hands on the wheel. |
The pulling may be that the alignment has now gone toe out? Also as you lower these cars the wheels tend to lean inward (negative camber). When you have the ride height where you want it and the bump steer kit installed you really should have it aligned.
From experience I know that these cars tend to wander a bit if they have any toe-out. For a street car that runs on roads that have crowning you really are better off with slight toe in. |
No doubt I need to refresh the whole suspension, but in the mean time, what other solution is there to gain correct camber without the car being too high? Monoball on the strut top? How close to the body can the 'normal' strut top be moved before it starts to hit the sheet metal? |
Correct, if you lower these cars sometimes you can't get rid of the negative camber. You also need to really cleanup all the undercoating from the adjustment bracket at the top of the strut. It also helps to adjust the bracket with wheels off the ground.
How close to the fender sheet metal can the strut top be moved? Moving it isn't the issue, it's how close to the outside is OK. 1/4 inch? |
To be clear, the top of the strut is in the bracket and the bracket is held to the body by the 3 bolts. You loosen the bolts and move the bracket, you don't move the strut.
And you can move the bracket as far as it allows, even if it hits the sheet metal does not matter. Quote:
^^^ Excellent, thanks.
ROW factory height should be at 27" to the bottom of the fender opening. At 27" your camber will be at zero. US height will be about 27 1/2" and your camber will be about 1/2 degree positive. How high up are your fenders? Cheers Joe 87 Carrera |
Sorry not trying to go off topic or hijack here but I noticed you have no lip on your whale tail . I have one in great condition. I will take 300 bucks or a nice set of H4's. I am getting ready to put it on the classifieds but I saw that you don't have one on your tail so I threw it out there.
I have the rubber in the garage. I took it off because it was pulling away from the tail. I took it off an found almost all of the metal inside rusted to dust. So I gutted the metal/rust and have to figure out a way to reattach the tail. I'm not really sold on the way the complete tail looks on the car, so I'm not sure what I'll ultimately do with it. Honestly, I think that aside from the rough edges and mounting holes on the rubber-less tail, I really like the subtle and less obtrusive look as it is. I've considered making a 'low profile' lip to go around the edge to give it a finished edge, but that's low priority at this point. I need to make sure it's mechanically safe and sound first. |
There are three ways to deal with the camber issue with a lowered car. Use a strut brace to jack the shock towers apart, raise the spindles, or have the struts de-cambered. Before I started driving my car on the track I maintained close to zero camber in the front with a ride height around 25" in the front by jacking the shock towers apart with a strut brace. So what if the gaps between my fenders and hood were large. I had no problem with tire wear. Funny how things change. Now days I want as much negative camber in front as possible. To help that I actually use my strut brace to pull the shock towers together. I don't commute in my car any more so the tire wear is not a problem. |
Found this thread on ride height.
http://forums.pelicanparts.com/porsche-911-technical-forum/546166-911-sc-lowered-ride-height-pics-measurements-please.html |
What I found by applying the factory method for the ROW (Euro) measurements, the 108mm (4 1/4"), equates to 27"F and the 12mm rear becomes 25 1/2"R. This is the result of restoring my 87 Carrera back to factory European (ROW) specifications. It makes one wonder if anyone has actually crawled under to take the actual torsion bar measurements or is it the inability to convert mm to inches that prevents us from using the factory method as it was intended? Correct me if I'm wrong, but nowhere in the Porsche Spec Book have I been able to find Euro heights of 25"F and 25"R based on fender openings. As far as I can tell, this is what ROW or Euro height should look like: http://farm6.staticflickr.com/5325/9...a1b1e6d5_b.jpg http://farm4.staticflickr.com/3826/9...7525697651.jpg http://farm4.staticflickr.com/3679/9...ed59f48b3d.jpg http://farm6.staticflickr.com/5511/9...6c184cd4_b.jpg http://forums.pelicanparts.com/uploa...1379967977.jpg http://forums.pelicanparts.com/uploa...1379968040.jpg http://www.912registry.org/graphics/...lrapp-1108.jpg Cheers, Joe |
You're not doing anything wrong. What people claim is "euro" height is nowhere near correct. The few that have bothered to measure it the right way are so astonished at the resulting height that they figure that there must be a typo in the factory numbers. A few brave souls have actually admitted that their cars drive better when raised to the correct height. Sadly, way too many people worry night and day about their car's "stance"... And nothing will likely change that.
JR |
My experience has been that the factory method was nonsense. My measurements using it never were anywhere close to reality.
Bruce Anderson in his "Porsche 911 Performance Handbook" states " What most people consider 'Euro Spec' is actually lower than the true European specifications. The correct ride height will result in a measurement of about 25 inches when measured from the ground to the rear fender lip." The 27" in the front may have something to do with bumper height regulations. Lowering the front to about 25 1/2" inches results in a more stable ride at the expense of less than optimal alignment specs and clearance issues. |
There were some years that the height was raised on US cars but eventually there was parity. I have no problem with lowering a tall US 911 to Euro height but having been down both roads I wish people would accept that Euro height isn't what everybody says it is. If confuses a lot of people.
JR |
Back in 67 there were no bumper height regulations and yet the 108mm front measurement still remained the same up to the 89 3.2 Carrera. Seems the factory knew something when they designed the 911 around this universally accepted ride height that some would call "nonsense". |
JR |
Why most feel that lowering results in better handling must be due to some overwhelming placebo effect just knowing of the lower center of gravity, extra negative camber, stiffer steering feel and last but not least, the "cool factor" 'cus they look so cool down low...and I'll be the first to agree, they do look pretty cool down low. |
Just trying to share my experiences. |
Upon reviewing my copy of "Porsche 911 Story" by Paul Frere, I find no mention of this strategy in the chapter "Improving handling and safety", but do find that all their wind tunnel testing was performed at a rather elevated European (ROW) attitude. It seems difficult for me to imagine that during all this testing that the engineers would overlook such an ingenious approach to improving handling and stability. For the record, there was no degradation of stability, in fact, quite the opposite happened when I raised my 87 Carrera back to ROW spec. I even found that it tracked straighter when taking my hands off the wheel at highway speed, compared to how it behaved before as it would tend to veer to the right. In short, the best description I have for the way my Carrera feels now is that it is more composed, stable and comfortable at highway speeds, just as the Porsche factory wind tunnel predicted. |
