993 cam upgrade with 50mm PMO's
Hi Guys ,can you please tell me if the you can run 993RS cams on standard 993 pistons .I am also changing to Solid Lifters so thought I would have the cams changed at the same time to give a little more .This is a track car only and is running PMO's .cheers Dave
Yes, you sure can.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
If you are changing to solid lifters then use the SS cam, not the RS. It's a tad racier and designed for solid lifter use.
How much hassle is it to switch to solid lifters?
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
MBruns for President
Any worries about knock or detonation?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Cams
Steve & Bill ,thank you for valuable info .cheers Dave
