Euro Carrera 3L ignition setup
Hello
You might advice me on the basic ignition setting for an upgraded 3.0 Euro carrera engine please ? (SSI exhaust, 964 cams, 9.8 CR) It works better with 5° BTDC, but what about max advance@6000RPM ? thanks Philippe
www.injectionsystemes.fr |
I'd set base timing at TDC w/ vac connected but check the timing to be sure that it does not exceed 38, if it does, go back to base 5° ATDC w/ the vacuum hooked up @900RPM the vacuum is a retard that goes away as the throttle is cracked
