Euro Carrera 3L ignition setup
Hello
You might advice me on the basic ignition setting for an upgraded 3.0 Euro carrera engine please ?
(SSI exhaust, 964 cams, 9.8 CR)
It works better with 5° BTDC, but what about max advance@6000RPM ?
thanks
Philippe
www.injectionsystemes.fr
Old 10-03-2013, 01:13 PM
Bill Verburg's Avatar
Originally Posted by philippeF View Post
Hello
thanks
Philippe
Max ignition advance w/ vacuum disconnected is 38°@6k
I'd set base timing at TDC w/ vac connected but check the timing to be sure that it does not exceed 38, if it does, go back to base 5° ATDC w/ the vacuum hooked up @900RPM
the vacuum is a retard that goes away as the throttle is cracked
Bill Verburg
Old 10-03-2013, 02:16 PM
