-   -   Seine gate shift question (http://forums.pelicanparts.com/porsche-911-technical-forum/774838-seine-gate-shift-question.html)
LjH 10-11-2013 07:54 AM
Had the kit in my 86 for about 4 years. Works flawlessly. I clamped it, adjusted it, spot wielded with the clamp on. Then removed the clamp and finished the wield. Did not have to cut the boot.;)
dnovick911 11-25-2013 08:55 PM
Adding on related question here...
My new-to me '85 911 has a seine shift kit and short shift installed.
The 3-4 channel requires slight, right pressure to shift from 2 to 3, or from 5 to 4.
Can I adjust somehow adjust to avoid adding pressure?? There metal tabs on the shifter are welded on. Thanks for any thoughts....Dave
Roger 911 11-26-2013 05:37 AM
The device is designed to require pressure, but not exactly as you describe. If it is adjusted correctly, the shifter should rest in the 3-4 when in neutral. Slight pressure to the left will put it into the 1-2 gate, and slight pressure to the right will push it into 5. I installed mine so long ago I no longer remember how to adjust it. However, that is also a testament at how well this works. It has never required adjustment.
If you don't get the info that you need here, certainly contact Seine.
Roger
dnovick911 11-26-2013 11:00 AM
Roger
Thanks Roger. Too clarify. At the appropriate velocity and motor speed to shift into 3rd gear, and with the shifter "at rest" in neutral (no hand pressure), IF I then push the shifter straight forward - it will not go into 3rd gear. In order to get the car into third gear, I "feel" for the spring and push slightly to the right (not all the way to 5th gear) - and then the car goes into 3rd. Basically the "at rest" neutral position is just a hair offline (left / right wise). Can I maybe bend the tabs? Do I have to remove the welds and redo? Other? Thanks again! Dave
McLaren-TAG 11-26-2013 11:13 AM
From your description it sounds like you need a hair of an adjustment at the coupler in the rear not the actual shifter in the front. There are a lot of documented threads on how to do that. As already mentioned, in the 3/4 plane the shifter should slide into 3rd and 4th without any lateral pressure required since it should already be automatically "centered".
Roger 911 11-26-2013 11:21 AM
Also make sure the bushings are in good shape, etc.
FWIW, I also replaced the shift rod coupler with an aftermarket one (Stomski Racing, if I recall). This helped to provide for much more positive gear selection as well.
Roger
