Not Royce
Royze's Avatar
BBS E-50 fitment questions
I'm currently running front 964 break calipers and 930 rear calipers, I would like to know the caliper space or enough space for future bigger break upgrades & also a safe offset without using spacers.
thank you for the advice,
Royze
Pistache: 1984 911 backdate
@RWB_Royze on IG www.instagram.com/rwb_royze
RWB Japan/Middle-East representative
Old 10-05-2013, 06:25 AM
Not Royce
Royze's Avatar
any input would be appreciated, i'm quite stuck on this issue as i can't progress with my project unless I have the correct sizes
Old 10-06-2013, 09:19 AM
Do you not have the car at your disposal to measure?
Here is a threads on 930 offsets.
This one says offsets of +17 front +6 rear on 17x9/11-inch wheels without spacers
or
Front Offset +31 (used stock spacers) Rear Offset +06 (no rear spacers)
Proper wheel offset for a 930 upgrade
As far as caliper offsets, the best way to be sure would be to put a straight edge on the hub and measure the distance to the caliper for measurement "A"
Old 10-07-2013, 05:20 AM
