-   -   sensor question (http://forums.pelicanparts.com/porsche-911-technical-forum/775303-sensor-question.html)
DSR 10-07-2013 12:52 PM
sensor question
can someone tell me what these 2 sensors are?
http://forums.pelicanparts.com/uploa...1381175448.jpg
http://forums.pelicanparts.com/uploa...1381175469.jpg
the first one is on the left side of the engine compartment and the second one is on the right side.
Thanks,
david
Flat6pac 10-07-2013 04:22 PM
The one to the left side is the cold start injector que
To the right of the fan is oil temperature
Bruce
Bob Kontak 10-07-2013 04:52 PM
Meaning it is the interface between how warm your engine is and whether or not CIS needs to spray extra gas through the cold start valve on the back side of your engine.
Engine hot, no need for an extra spritz to get her going. Actually, it's pretty robust when the CSV sprays.
Sensor is also called the thermotime switch. It's more of an on off decider - hence the term que.
DSR 10-08-2013 05:40 AM
thank you!!
P Moore 10-08-2013 03:11 PM
Sorry to jump in ..
So when converting over to Webers the sensor to the left can be disconnected.. ?
Jack Stands 10-08-2013 03:30 PM
Thermal time switch
It shouldn't be needed if you converted to Webers. However, it sure would be nice to be able to choke down the Webers when starting from cold as your leg can get quite tired keeping the engine running until the Webers are able to keep it going!
