DSR DSR is offline
DSR's Avatar
sensor question
can someone tell me what these 2 sensors are?
the first one is on the left side of the engine compartment and the second one is on the right side.
Thanks,
david
Old 10-07-2013, 12:52 PM
The one to the left side is the cold start injector que
To the right of the fan is oil temperature
Bruce
Old 10-07-2013, 04:22 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Meaning it is the interface between how warm your engine is and whether or not CIS needs to spray extra gas through the cold start valve on the back side of your engine.
Engine hot, no need for an extra spritz to get her going. Actually, it's pretty robust when the CSV sprays.
Sensor is also called the thermotime switch. It's more of an on off decider - hence the term que.
1981 911SC Targa
Old 10-07-2013, 04:52 PM
DSR DSR is offline
DSR's Avatar
thank you!!
Old 10-08-2013, 05:40 AM
Send a message via MSN to P Moore Send a message via Skype™ to P Moore
Sorry to jump in ..
So when converting over to Webers the sensor to the left can be disconnected.. ?
Old 10-08-2013, 03:11 PM
Vintage Owner
Jack Stands's Avatar
Thermal time switch
It shouldn't be needed if you converted to Webers. However, it sure would be nice to be able to choke down the Webers when starting from cold as your leg can get quite tired keeping the engine running until the Webers are able to keep it going!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-08-2013, 03:30 PM
