73 Front Trunk Carpet Question...
In the attached photo (one of Pelican's offerings for trunk carpet sets) there is a smaller section shown between the two trunk side carpets.
I have an original set in great shape that I have cleaned up for re-installation. However, that smaller piece has evidence of having been "contact cemented" along one edge. Problem is, I can't figure out where it was originally attached by the factory. I am afraid I cleaned up the trunk to well to find evidence of the cemented area. Can someone shed light on this as to where it is supposed to be glued? Regards, Bill http://forums.pelicanparts.com/uploa...1381353526.jpg |
I think it may have been glued to the side felt and held a plywood stretcher in place, but going on memory from a long time ago. Mine is missing. I'm sure someone else I will know for sure.
This is from memory also. In my 73, I believe the short piece with the plywood insert had one side glued under the lip of the front bulkhead--under where the trunk latch mechanism is located--to the vertical sheet metal. Could be mistaken, but check to see if that fits the location of the piece and the cemented edge.
| All times are GMT -8. The time now is 03:05 PM. |
