carnut169's Avatar
Ta Da!....and what color to paint the shroud
If any of you noticed earlier today I was having a bit of trouble removing the fan assembly but finally got it. Polished up the fan and:
So I have also blasted the shroud and was thinking about painting it. Powder coat? Brake caliper paint? Polish it up as well? I thought I could just get some good brake caliper paint and paint it black myself. Next is the strap which I have had a look at removing- it looks like a pain, but should it be painted as well? If I went w/ the black shroud, and the polished fan, what to do with the strap... red?
Sean O.
Atlanta, Ga.
96 Van Diemen Formula Continental
01 2500HD
Old 07-14-2002, 07:49 PM
carnut169's Avatar
This is what it looked like a few hours ago:
Sean O.
Atlanta, Ga.
01 2500HD
Old 07-14-2002, 07:54 PM
Buy them, sell them
Adam's Avatar
Looks great, Sean.
What did you polish it with? I have a bench grinder with buffing wheels on it, so it'd be an easy job for me.
I hope you hook up that plug lead before you drive it next, too!
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 07-14-2002, 07:58 PM
Botman's Avatar
Looks Great! What was the issue in getting it out earlier?
Mike Patterson
Obsessive in Texas
86 3.2 Black on Black Carrera Coupe
73 BMW 2002 Verona Red
Old 07-14-2002, 08:00 PM
carnut169's Avatar
I used glass beads to clean it up, then 400 grit wet, 600 grit wet, a drummel (things are waaay to small), and then polished it about 5 times with Brasso and Never-Dull. Could still be better, but I am happy it looks as good as it does considering the time and what I started with.
Here is the earler post:
Need help w/ alternator removal!
Sean O.
Atlanta, Ga.
01 2500HD
Old 07-14-2002, 08:03 PM
Banned
that looks good!!
i polished my fan too but its got bubbles and crap on it
what did you use to make it shiny??
Old 07-14-2002, 08:04 PM
APKhaos's Avatar
Now THAT is a beautimous thing! Congrats.
You might want to think about a decent 2-part clear coat to keep it looking like that - the magnesium alloy tends to discolor fairly quickly due to oxidization.
The question of colors is a hard one - there are lots of examples on various recent threads. Powdercoating is the clear winner here - it's durability is the best for the interior surface of the shroud which takes a pounding from dust particles in the very high speed airflow around the circumference of the fan.
If you are going with black for the shroud, then polishing a clearcoating the strap should look really good with your polished fan. Too many colors is bad boogee imho.
The strap is a pig to remove - you will need to remove the AC compressor and the oil pressure sender to create enough clearance to get that puppy out. Alternative is to remove the distributor, but safer to work the other side.
Should look great when you get it done - waiting for a pic!
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 07-14-2002, 08:09 PM
Bird. It's the word...
Fishcop's Avatar
The trick is to keep it shiney!
Magnesium (the fan) does not hold a bright surface for long.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 07-14-2002, 08:10 PM
The magnesium will indeed corrode quickly, especially if you used steel wool to polish it. Small pieces will come off on the magnesium surface and accelerate corrosion. If your sand paper had any metalic particles in it, that will accelerate the corrosion too.
Eric Purdy
Old 07-14-2002, 08:20 PM
autobonrun's Avatar
You did a great job.
I also polished my fan. The metal belt was so difficult to remove, I left it in place and polished it also. You can use steel to polish it although you shouldn't use steel on the magnesium fan.. I powder coated my shroud red.
Old 07-14-2002, 08:35 PM
CamB's Avatar
Powdercoat the shroud if you can (for durability).
Is clear powdercoat available??? For the fan?
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 07-14-2002, 09:02 PM
FlaCarrera's Avatar
How about chrome plating both fan & shroud? A curious neighbor mentioned this as i puttered away under the hood yesterday.
Ted in finnally sunny Fla
86 Carrera Targa Blk/Blk
Old 07-14-2002, 10:59 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I did mone several moths ago. Mine looked like that, but after driving for several weeks it went back to the same grey dull finish! I had the shroud powder coated black and polished the strap just like the fan - looked great. Curious if you can clear powder coat the fan?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-15-2002, 03:49 AM
Hi Sean
I polished my fan too, and every week I had to clean it. I put clear coat on but it didn't stick. End result, I finally got fed up with recleaning, and let it go back to its 'original look'.
Good luck.
Daniel.
Old 07-15-2002, 04:01 AM
Banned
someone needs to invent a way to chrome mag
Old 07-15-2002, 05:32 AM
APKhaos's Avatar
Clear powdercoat may be the answer for the fan. I used it on the induction manifold [pic in my earlier post this thread]. The polished fan looks the best, and clear powdercoat will keep it looking good. Check with your local PCA guys to find a local powdercoater who understands complex alloys - the patio furniture guys are trouble!
BTW< if you are going the powdercoat route, you will need to remove around 0.5mm length from each fan blade to allow for the thickness of the powdercoat.
Tony K
'89 944T
TrackVision
944Cup
The 999 Site
Old 07-15-2002, 08:07 AM
skinnerd's Avatar
Although I didn't polish the fan, here is a view of the shroud powder coated black. Mine has a slight texture to it, but not enough that the ends of the fan blades hit it. For the fan, I drilled out the rivets and had the hub re-cad plated. I had the fan itself bead plasted, then treated with Alodyne (used in the aircraft industry to seal alunimum), and then clear coated. The refinished hub was riveted back on the fan. The strap was also re-cad plated as well. Maybe not exactly what some of you are after, but another option.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 07-15-2002, 08:42 AM
APKhaos's Avatar
Nice work, Doug.
Really like the engineered look that the cad plating gives - much better imho than some of the technicolor finishes we've seen.
Tony K
'89 944T
TrackVision
944Cup
The 999 Site
Old 07-15-2002, 08:48 AM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Hey Carnut.. very nice job..you are now known as "Polish Nut"
I spoke with a buddy of mine who owns and operates a very well known powder coating shop here in the Bay Area.
He said you can Clear Powder coat your Fan and should look nice for at least a few years.
another option that I have seen is Electroless Bright Nickel Plating MIL-C-26074 CLASS 3 GRADE B with a nice polished fan like yours it will look very good.
Nickel is very durable and will not fade.
Jorge (Targa Dude)
Old 07-15-2002, 10:34 AM
aseem's Avatar
Nice polishing job.
I'm confused. I thought the "shroud" was the the "tinware" covering the engine, leading the air from the fan over the cylinders. Most of the repliers on this thread seem to use "shroud" when refering to the fan housing.
Ref.
Shroud and Fan Housing
According to Peter Morgan, you can tell if it is a T, E or S by the color of the cooling shroud. The T had black or yellow. The E was green and the S was red.
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 07-15-2002, 03:32 PM
