How do I install the rear reflector?
When I pulled the reflector off, the clips stayed attached to the reflector. Do I reinstall it with the clips on the reflector or do I pull the clips off and install them on the car then push the reflector into the clips?
http://forums.pelicanparts.com/uploa...1381697113.jpg |
When I installed a new, later model, black script rear reflector to my '79SC I pushed the rectangular clips into the steel support panel first. I also adjusted each clip to accomodate the reflector round plastic boss without too much pressure. And I made sure that the rectangular clips can move sideways inside the rectangular cutouts of the reflector support panel. Then I just pushed the whole reflector carefully into the support panel with the clips installed. I only supplied pressure where the gray plastic brackets are glued to the back of the reflector.
Are those clips available anywhere?
Thanks Porwolf, that is what I was thinking.
Mark, I would imagine they are but I didn't see them in the Pelican online catalog/ |
| All times are GMT -8. The time now is 05:25 PM. |
