Tired Member
How do I install the rear reflector?
When I pulled the reflector off, the clips stayed attached to the reflector. Do I reinstall it with the clips on the reflector or do I pull the clips off and install them on the car then push the reflector into the clips?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
When I installed a new, later model, black script rear reflector to my '79SC I pushed the rectangular clips into the steel support panel first. I also adjusted each clip to accomodate the reflector round plastic boss without too much pressure. And I made sure that the rectangular clips can move sideways inside the rectangular cutouts of the reflector support panel. Then I just pushed the whole reflector carefully into the support panel with the clips installed. I only supplied pressure where the gray plastic brackets are glued to the back of the reflector.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
non-whiner
Are those clips available anywhere?
"Too much is just enough." |
Tired Member
Thanks Porwolf, that is what I was thinking.
Mark, I would imagine they are but I didn't see them in the Pelican online catalog/
From my memory I thought I remember buying some 2 years ago somewhere. Tried to retrace my records but cannot find the possible source right now. If needed I could do some deeper research.
