-   -   Installing Pertronix Points - Change Coil Too? (http://forums.pelicanparts.com/porsche-911-technical-forum/776343-installing-pertronix-points-change-coil-too.html)
Quickstep192 10-13-2013 03:05 PM
A friend recommended I replace my old conventional points with Pertronix. If/When I do this, should I change the coil too? If so, what coil(s) should I consider?
(I need $18 more to qualify for free shipping :)
Bob Harriman 10-13-2013 06:15 PM
I would. Ignitor coil. I believe it is a petronics product also.
grant lyon 10-13-2013 10:32 PM
Suggest distributor rotor & cap (wear items). Or, magnecore wires. I used original coil 20+ years after installing a pertronics ignitor for my 2.7L.
mskala 10-14-2013 09:46 AM
Whether or not you should change your coil has nothing to do with the decision to use Pertronix or normal points. Pertronix still performs the same function as a switch (but not requiring typical points maintenance). It does not affect how your coil works.
If you upgrade your computer keyboard should you also replace the cpu? :)
Jubbie 10-14-2013 10:01 AM
On my 74 911, I put a pertronix in with my original coil back 8 years ago and it has worked fine.
Jerome74911S 10-14-2013 11:24 AM
Ditto. The coil's function does not rely on points or Pertronix. I have Pertronix with original coil - works fine.
thumbdoctor 10-14-2013 12:25 PM
The only upgrade which would require a coil upgrade would be an ignition amplifier such as a an allison or XR 3000 because the primary voltage is stepped up and the coil saturation is increased. As said a good inspection of the secondary ignition parts is in order.
Quickstep192 10-14-2013 04:58 PM
So far my list is:
Pertronix points
Rotor
Cap
Plugs
maybe coil----
should I do wires? Any favorites? This isn't a race car... I don't mind power and performance, but smooth running is my top goal. I'd like to order everything from Pelican.....
Tidybuoy 10-14-2013 05:14 PM
I think it depends on the condition of the car and how new it is to you. With me, I bought a good condition '74 but I ultimately replaced everything on your list + wires and fuel & vacuum lines. I did this just so that I knew for myself when everything was last changed.
My car came with a petronixs but still had the original coil. It has worked fine for many years.
thumbdoctor 10-14-2013 06:47 PM
So far my list is:
Pertronix points
Rotor
Cap
Plugs
maybe coil----
If you want to replace the coil, The Accel Super stock coil is friendly with all electronic systems and not hard on the pocketbook.
dfhtrhjn 10-15-2013 12:19 PM
I've got the pertronix points with the pertronix flame thrower 2 coil. I put it in about 3 years ago and seems to work nicely.
