SC wheelspacers
I've searched previous threads to no avail, so here goes. I have a 1983 SC with the original 16x6 and 16x7 fuchs, all original panels, no accident history, ect. Is there a general consensus out there re: wheel spacer width to help fill in the wheel/tire width? I don't recall where I read or heard this, but common sizes are 7mm fronts and 21mm rears? The car has been lowered at some point, with ~25 inch front, 24.5 inch rear fender lip to ground, measuring through the center of the wheel. No rubbing currently, and it appears the fender lips have never been "rolled".
Old 10-13-2013, 08:22 PM
nineball's Avatar
Looking for wheel spacer guidance...'83 Targa
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 10-13-2013, 08:44 PM
Rescuer of old cars
Arne2's Avatar
I don't have any on the front, but do have 1" (25mm) rear spacers on mine. That gives the same fender fill as the factory 16x8 wheels, and should be totally safe even on a car as low as yours. Makes a big difference in the looks.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-13-2013, 08:45 PM
Rescuer of old cars
Arne2's Avatar
Mine are bolt-on, CNC made by a small family machine shop in Nevada. Affordable, and good quality, not Chinese stuff.
2018 718 Cayman 2.0
Old 10-13-2013, 09:39 PM
Air Cooled
Craig_D's Avatar
Arne, who makes them and how do we contact them for pricing?
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 10-13-2013, 10:59 PM
tuchan's Avatar
Send a message via MSN to tuchan
1" here
Goose- "nothing a year in the tropics wouldn't fix"
Old 10-13-2013, 11:58 PM
GothingNC's Avatar
23 MM H&R Adapters with 7 inch Fuchs.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 10-14-2013, 03:05 AM
theiceman's Avatar
If you wanted the same fill as the 8 inch Fuchs, wouldn't you 12mm spacers? Wouldn't it be half an inch on either side of the offset?
Or is the offset on the 8 also reduced 12mm to give you the full inch on the outside?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-14-2013, 03:41 AM
weekend wOrrier
I think it is this one. I just went through all of this on my car. Spent a lot of time using the fuchs offset chart to figure this all out, but then proceeded to forget it all. IIRC:
7's+ 1 inch spacers about equal to 8's with no spacer.
The nines are about 1/4 wider on the outside than the 8's, but they magically still fit.
...or something like that.
Ron
Old 10-14-2013, 05:24 AM
theiceman's Avatar
Thanks Ron
If the 8 inch sits a full one 1 inch towards outside of the car then a reduction of half an inch in offset would be required, or about 12.5mm. Vs the 7 inch fuch.
Good to know
Old 10-14-2013, 06:08 AM
theiceman's Avatar
So I would be looking for a one inch hub centric adapter and could use original lugs.
Old 10-14-2013, 06:10 AM
bennysc1
I like the look of Nineball car with the 23MM spacer as I have 7's on the back of my car. I looked up H & R spacers and they show two model's. One is a DR and the other is a DRS. Which one would best? I would prefer not to use longer studs if possible. Any suggestions? My car is a 83Sc coupe.
Old 10-14-2013, 11:15 AM
nineball's Avatar
the drs only comes in thicknesses up to 15mm, the drm go beyond that. mine were 23mm so that means they were drm.
the drs is just a spacer, so you would need to buy longer studs if using them. the drm have studs in them already.
Old 10-14-2013, 03:31 PM
bennysc1
Nineball,
Thank you for the information. I take it that perhaps went with the DRM version with studs already? Do you know where to buys these spacers locally. I am in Cleveland, Ohio. Summit Racing does not carry the H & R brand. They did not have any spacers at 23MM. Any suggestions would be great. I will check our hosts website.
Old 10-14-2013, 06:37 PM
Ova Day
msterling's Avatar
Our host carries some spacers and has studs. They didn't have the spacers I wanted. I used 14mm H&R spacers on my 88 Carrera to move 7x15 et23 Cookie cutters out 1/2" on the rear. They are spaced about like the 8x15 et10.5 Fuchs that came with the car. I had to install the longer studs that came with the spacers. I now run the Fuchs with the spacers as they are not pushed out too far. For 23mm you would need to used bolt-ons which are a lot easier to install.
PM me for an alternate source.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 10-14-2013, 07:11 PM
Senior Advisor
James Brown's Avatar
i used turbo spacers and longer studs, cheaper and i like the long stud look, makes me go faster
08 Cayenne Turbo
Old 10-16-2013, 01:55 AM
Been here a while
You might want to tell us your location, I'm in north NJ and have some various spacers you could try.
looking for 1972 911t motor XR584, S/N 6121622
Old 10-16-2013, 04:20 AM
theiceman's Avatar
I will be looking for the DRM version as i would have the following issue.
I actually run two sets fo wheels .. okay 3 but we wont go there.
The car came with gold "BBS style" and although they looked period correct for 1978 I just didnt like them. I bought a set of CUP wheels from Tirerack with 17s on them ( okay shun me all ) . The 17s offered much more variability on tires and they do fill out the wheel wells really nice and have excellent grip with a set of RE050 on them ( 7.5" front and 11 inch rear I think ) ...
anywho ..
I finally did find a set of reasonably priced fuchs and decided to put all seasons on these wheels as i already had a set of high performance tires on the 17s. This allowed me to have all seasons fror driving fom mid March to end of May and Late October to december in canada as high performance tires are no fun when you cant get heat into them.
With having these two sets of wheels I have to be able to add adpaters for the Fuchs and remove them for my cups, If i just used spacers with longer studs I would have to remove the spacers when i put the 17s on to get them to fit and then se open nuts as the studs would be too long.
so i would personally rather just take the studed adapter off and use the 17s against the rotor with original lugs. Something to consider if you change wheels as i do a couple of times a year ..
Fuchs fan boys flame away
Old 10-16-2013, 05:09 AM
83 Targa
I have an 83 SC with 1 inch spacers on the back. I will probably have to trim these back to 21 MM if and when I lower the rear. When i just eye up the lowering job, I think the 1 inch could rub. I should get a fat guy to push down on my my bumper to confirm it.
They are the bolt on type and work fine and fill the wheel well out nicely.
Old 10-16-2013, 06:49 AM
nineball's Avatar
sent him a pm a couple days ago offering to try mine out as we are less than 30 mins apart, never heard back. even told him there is a chance he could talk me into selling them
Old 10-16-2013, 04:00 PM
