need help-in process- (plug wire change)
I am in the middle of changing my plug wires to 10mm magnecor wires. The stock wires have some kind of grounding strap coming off each stock wire...not on the magnecor. Do I need to do something here, or are the aftermarket wires different and not need a "ground". I will not reconnect the battery untill I hear from you guys....thanks.
------------------ Jeff '79 930 http://www.pelicanparts.com/gallery/jkcrewsn |
Just remove the braided grounds and chunk 'em with the old wires. You don't need them.
------------------ Robert Stoll 83 SC 83 944 |
Many thanks!! You guys are awesome. As is this board....
| All times are GMT -8. The time now is 11:50 PM. |
