Always Be Fixing Cars
Jetnuts on exhaust parts? What technology are the factory locknuts?
There are several threads on exhaust fasteners. I used extra fancy jetnuts from Coastfab on my alfa, and noticed that McMaster sells some but only in SAE sizes. See 98892A600 for instance for a 5/16" Silver-Plated A286 Super Alloy jetnut. This is a high temp locknut. These could be used with 4/15th studs on the X-over and similar exhaust parts where one side of the stud is not threaded into alum.
Does anyone know what type of locking action the factory M8 nuts have: Pelican Parts - Product Information: 900-910-097-02-OEM ? Are these deformed? There are no lock washers visible.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 10-15-2013, 06:46 AM
LJ851's Avatar
Originally Posted by r-mm View Post
Are these deformed?
Yes.
Old 10-15-2013, 07:53 AM
Are the M8 hex nuts holding the heat exchangers (#4) to headers locknuts? The PET suggests that are plain nuts.
The M8 nuts on the x-over pipe (#8) are indicated as locknuts.
Old 10-15-2013, 06:47 PM
Sort of interesting discovery - the M8 nuts on the 930 (#7) are listed as locknuts whereas their counterparts on the NA car are not...
Old 10-15-2013, 07:31 PM
Senior Advisor
James Brown's Avatar
high temperature lock nuts are mostly interference fit (deformed) and may not be noted in the parts catalog. i have used plain nuts and have had no problems.
08 Cayenne Turbo
Old 10-16-2013, 01:24 AM
