-   -   and what sadistic SOB designed... (http://forums.pelicanparts.com/porsche-911-technical-forum/77761-what-sadistic-sob-designed.html)
nostatic 08-16-2002 07:39 PM
the front left hood shock mount. I finally just put the pin in, pocketed the clip, and called it a day...maybe if I take some meds I'll try again. I cannot for the life of me figure out how to get the lower pin in from the back side (so I can get the clip on) unless I start ripping stuff out from around the mount. Like the gas tank filler...that's a good place to start.
pbs911 08-16-2002 07:48 PM
That's exactly what I did three years ago and the pin never came out until I took it out last weekend. You should be fine. You see. only two parts actually began the production line process at Porsche in those days. The little clip you speak about and the clip that goes on the clutch peddle assembly. Wait till you try the latter!
Hockey fan 08-16-2002 07:58 PM
I second the "pin in, no clip" method. I did the same thing and the pin has stayed put just fine. There is a good thread regarding the pin and clip replacement with those little medical clamp-things (can't remember the Marcus Welby name right now). I actually had to have the girlfriend get her much smaller hand in there to get it back together. Nostatic - time to get the wife a pair of weekend coveralls!:D
Jeff
diy83sc 08-16-2002 08:00 PM
I had the same problem to deal with a week after I bought my car. I think this is why the previous owners sell theirs :) Ever watch gumby?
jwetering 08-16-2002 09:50 PM
Nostatic...you bought a car?!? I must've missed the post - congrats. I'll go search for pix...I assume they're there.
nostatic 08-16-2002 09:54 PM
I don't know about that, but she did remind me tonight to get more life insurance. So either she's just worried, or her supporting the car purchase is part of a movie-of-the-week master plan. I better check my brake lines :)
Hockey fan 08-16-2002 10:01 PM
Nostatic - has she recently watched the original version of "The Postman Always Rings Twice"!:D
Seriously - congratulations on the new car. I had been lurking here for a couple months while I looked for my car and enjoyed your posts. The day you bought the car I actually called my wife at work, below is the conversation:
Me: Hi it's me. Guess what? That guy Nostatic finally found a car.
Wife: I thought he had one?
Me: No, remember, he had one but sold it. He just got a new one.
Wife: That's great, can we see pictures when we get home?
Enjoy the car.
Jeff
nostatic 08-16-2002 10:05 PM
Holy crap...that was on last weekend. I went to bed and she stayed up and watched it until the end. Oh this can't be good... :p
Good to know I'm (in)famous in households around the world. Now if only I could figure out a way to make money off it...
Don Plumley 08-16-2002 10:14 PM
I have. I'll be purchasing a life insurance policy on you, naming me as the beneficiary. Nothing too greedy, just enough for a 993tt...:D
HarryD 08-16-2002 10:51 PM
Not sadistic, quirky!
rstoll 08-16-2002 10:58 PM
And what did you name "your" clip and the guy that designed it's location??? ;) :confused: The return spring on the clutch pedal will help build your abs too, as you try to fit it. I can feel you are enjoying the car. BTW, I am clipless on that side too. :)
ChrisBennet 08-16-2002 11:28 PM
It's a 10 minute job if you make a little tool to hold the pin (female spade connector on a coat hanger wire). I think I held the clip with needle nose pliers or the medical equivalent (hemostats?). Those skinny medical pliers people used to use to hold joints/remove fish hooks/hold blood vessels shut.
-Chris
speeder 08-16-2002 11:56 PM
That particular procedure is a nut-buster, when I bought my SC the hood shocks were shot. I bought new ones, and to this day only the passenger side has been installed. Going to have to try the methods described here; kind of forgot about it since the one new one holds it up. :cool:
pkfrdh 08-17-2002 05:30 AM
Can't get the clip in the pin?
Put a bolt and nut in place of the pin...it works fine!
JGL;)
john walker's workshop 08-17-2002 08:38 AM
i cheat on the pin too. pop the clip off with a long screwdriver, push out the pin with a 90° hook tool, fish it out with a magnet on a stick, reinstall it from the outside with needle nose pliers, and stick a small blob of dum-dum over the head.
yelcab1 08-17-2002 08:42 AM
I did this procedure 3 times, I did what JohnWalker did with a dum dum glob. One time, I managed to spend an hour and did it right with the clip, but it was not fun, a contortionist act, or you must have 9 fingers, 3 hands the size of my one-year old.
Carl Bauer 08-17-2002 01:20 PM
I'm suprised the clip was even there for you guys. When I replaced my hood shocks it wasn't and the job was a bunch easier because of it! It's not as if the pin is going to pop out with the shocks compressed when the trunk is closed.
billwagnon 08-17-2002 04:27 PM
I think that was the first job I did on my car - 101 Projects estimates 1 hour, I took 2 or more. My son was holding the flashlight and my hand was bleeding where the air cable scratched it. But I got it in there. I think it's one of those deals where you have to teach your hands where everything is because you can't see much while they're in there! :)
gr8fl4porsche 08-17-2002 07:27 PM
I just installed more hood struts AGAIN today. I am getting very good at putting in the pins with the clips. I use hemostats and dentil floss - start to finish in less than 15 minutes.
My problem is that the new struts push up the rear end of the hood. I tried Weltmeisters and now Vertex's heavy duty's - both caused the same problem. I am going to pull them out and rig up the fibreglass rod. I am done with hood struts.
targa911man 08-19-2002 09:15 AM
nostatic--
If you think the front hood shock is a pain, wait until you have to mess with the rear lid shock(s).
