Porsche Crest crank pulley
Does any have pics of how to remove the crank pulley? Im planning to install Electromotive ignition. Thanks
Old 07-11-2013, 09:08 PM
Grappler
Rodsrsr's Avatar
What kind of car do you have? Year, motor, ect? On my 3.2 I just used an impact gun and it came right off.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 07-11-2013, 10:11 PM
Thanks...I have an 82SC. My question was about removing the tin so I can get at the pulley.
Old 07-11-2013, 11:41 PM
Crank pulley removal........
Kremer,
I am assuming you have the engine on an engine stand and trying to remove the crank pulley. If this is the case, you simply loosen/remove the fasteners (bolts) that secure the engine tin to the chain covers and side engine tin. Then remove the 4 nuts and engine bracket to gain access to the crank pulley bolt. The muffler has to be removed too before you are able to remove the engine bracket. An impact is an ideal tool to use for this kind of job. Quick and easy.
Otherwise, use a breaker bar and a flywheel lock for the crank pulley removal. Keep us posted.
Tony
Old 07-12-2013, 06:08 AM
midnight911's Avatar
looking at my notes, i removed bumper, muffler, heater cross pipe, and then removed the engine hunger cross member with jacking the engine up. no mention of removing the tin.
used 120V impact to remove the bolt.
make sure the seal goes in straight. i used a pvc pipe end with diameter similar to the seal with success.
when torquing the pulley bolt at 180lb/ft or something like that, i just put e-brake and gear in 5th and that was enough.
good luck.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-12-2013, 10:50 AM
Taking it apart is easy
Jerome74911S's Avatar
I was part of the 'pit crew' for a friend during a DE day.
His son was driving the car when that bolt came out and the pulley flew off as the car was doing 6,000 rpm in fifth gear on the back straight.
The pin that keeps the pulley from turning had sheared. We did a partial engine drop, yanked off the muffler, tin, mounting brackets, etc., drove to the next town for parts and got the whole car back together and on the track, missing only one session.
In other words, it isn't hard to do when you are determined. I'd do a partial drop - if your engine isn't out already - undo whatever is in your way and take an impact gun to it.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-12-2013, 01:29 PM
Discseven's Avatar
Kremer2... here are some views of the crank pulley area on an '85.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-12-2013, 02:44 PM
Thanks for all of the great response from all members!!! Bill
Old 07-12-2013, 06:51 PM
Functionista
manbridge 74's Avatar
I found this easy on a non-AC mid year. You only need a box end 19mm wrench, strap wrench and cheater pipe. No need to remove anything else for access.
I plan on using the OE 116mm pulley for cold weather and will use the 134mm pulley in the hotter months.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-24-2013, 07:14 AM
