-   -   Any thoughts on if this can be repaired (http://forums.pelicanparts.com/porsche-911-technical-forum/778864-any-thoughts-if-can-repaired.html)
Uncle Enzo 10-28-2013 07:47 PM
Its not pretty and the PO did try to have it welded. Not the end of the world but not really thrilled.
http://farm6.staticflickr.com/5516/1...2bec6596_z.jpg
Joe Bob 10-28-2013 07:54 PM
To do it right, the panel needs to be cut out and a replacement welded in.
OR get another door. When it's opened up by a pro, you'll know more.
Not a patch type job.
Uncle Enzo 10-29-2013 06:17 AM
The car has a fresh paint job so I would love to avoid a new door. Ill have to rip it apart this weekend and see whats going on .
manbridge 74 10-29-2013 06:21 AM
Take it to a GOOD welder and get an opinion.
onboost 10-29-2013 06:28 AM
Not that big of a deal to fix.. I've seen worse.
Disassemble the door panel.. Mark you pwr window wires if you have them.
Pop the pin out of the door stay, the pop-out both the hinge pins punch and dead blow hammer. By doing this, you don't loose your door alignment. Take the door to a good welder for the fix.
Uncle Enzo 10-29-2013 09:51 AM
Thanks guys. I think ill do just that. So no JB weld? ;)
Bergo 10-29-2013 12:47 PM
feel your pain, fresh paint on my car year before last, the same thing happened to me last week. Mulling over whether to get a new door or try to repair.
redridge 10-29-2013 01:31 PM
go with the repair... getting a new door would suck!
AVDCAV 10-30-2013 03:54 PM
I certified welder would laugh at that " take the door off mask the heck
Out of it and bring it to a real welder , little bit of touch up paint and
All good again. I wouldn't even contemplate a door change with that.
Just measure the door gaps make some paint stick jigs for the re hang
That's a good weekend project. Good it's a nice clean break and not a Nasty
Ripping separation .
wayner 10-30-2013 04:05 PM
I discovered the same thing on my replacement door just after I had it painted. Argh!
The metal around that spot was too brittle to weld and had to go inside the door to do the repair. It turned out fine but would have been better if the seller had told me that is why he removed the door from his car so that I could fix it before the paint job.
I never knew that these cars were prone to that and never thought to check.
john walker's workshop 10-30-2013 05:43 PM
a new picture with better lighting or a flash would be good. really can't see the problem very well. there's a repair kit from pelican that requires no welding, but yours looks like an outside tear, which is unusual. hard to see though.
PCA7GGR 10-30-2013 06:28 PM
Super glue - if that doesn't work - GORILLA GLUE it!
boxster03 10-30-2013 08:51 PM
On Wheeler Dealers Ed would get the door off - cut a patch piece of metal and tack weld that baby in - a little rattle can primer and some close to match Porsche green - fixed for a $1.99
Norm Faustino 10-31-2013 05:40 AM
I would FIRST go to Ace hardware or wally world and buy a roll of white contact paper and cover the whole door twice, after applying a coat of wax to it and a couple of insurance layers on the edges. Then take it off and bring it to a CERTIFIED welder. The door will thank you and he will thank you. :)
