r_towle's Avatar
Humming sound
So, I have this humming sound.
Not speed related, random and I cannot control when it happens.
It does not always happen when it cold, and after a while it comes on and goes on and off at random.
I can make it stop by hitting the brakes.
So I replaced the front bearings. And ball joints.
Came back the next day.
It vibrates the steering wheel, and the tone does not change like a cv joint or bearing would do.
Here is the odd part.
When I just touch the brakes, just enough to get the brake lights to activate, but not enough to get the brakes to apply, the noise stops.
A friend suggested it may be electrical...
This is a 1984 Carreras convertible with 240k miles...
So I read about the in tank fuel filter sock, and how a warm or hot fuel pump will hum.
I may do that swap anyways just because of the high mileage.
This car has hummed since I bought it over two years ago, and I replaced the fuel pump and fuel pump relay (under the seat) at that time so I would not end up being stranded...
Still humming, and has gotten louder now.
Rich
Old 10-28-2013, 05:45 PM
1983 911SC Chiffon Weiss
mlfox's Avatar
Could be a brake caliper piston not retracting, letting a pad drag against a rotor.
Regards,
mlfox
Old 10-28-2013, 06:37 PM
r_towle's Avatar
Thanks,
Checked all of them....
Old 10-28-2013, 06:47 PM
Reiver
Reiver's Avatar
check everything in your parking brakes.
Old 10-28-2013, 07:21 PM
r_towle's Avatar
Did not change nor stop when I used the parking brake while driving....
Old 10-28-2013, 08:32 PM
r_towle's Avatar
New ideas?
Old 10-29-2013, 05:54 PM
theiceman's Avatar
pad hum . did you you use that anti brake squeel stuff ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-29-2013, 06:38 PM
