SMHemmah
hemmah's Avatar
12V terminal in the engine compartment MSD supply?
Is the 12V terminal point in the engine compartment a good contact for the +12 power supply for an MSD 6201 box? The MSD install instructions say the +12 power supply should NOT be the alternator and that 12V terminal point has the alternator connected to it.
The 12V terminal point is always hot. So it is a direct contact to the + side of the batteries. Should be a solid 12V power supply to connect the MSD +12V power supply.
Suggestions?
Thanks,
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 11-07-2013, 02:38 PM
I had mine there with no problem.
Kinsley
1980 SC Targa - MS2, EDIS
Old 11-07-2013, 02:59 PM
ROW '78 911 Targa
timmy2's Avatar
12 volt supply at the alternator is connected directly to the starter positive terminal and connected from there directly to the battery.
Also connected directly to pin 14 in 14 pin connector...
Old 11-07-2013, 05:54 PM
SMHemmah
hemmah's Avatar
Thanks Kinsley and Timmy
The MSD is working the Tach is not working. Common problem.
Old 11-07-2013, 06:51 PM
