Sanding / Planing valve covers
Doing valve adjustments. I used 220 grit sand paper (is this a decent grit for this?) to plane the contact surface of the valve covers. Cant seem to get it completely bright. There looks to be a small area that is barely warped... its at the corners where there are no bolts. How close do I need to get so that the gasket can take up the difference? Looking at the pics, the black marks are the areas that barely got sanded. Am I close enough? Thanks!
abit off center
looks good to me, more important its done on a flat surface..
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Yup! Sandpaper glued to piece of polished granite.
One way to sand smooth is to take a piece of glass (laying on a flat surface), pour a little oil on it and then lay the sand paper on it. The oil will help keep the sandpaper locked onto the glass. I did this when I sanded the paint off the Porsche letters on the valve covers and I suspect that this would work well for the gasket side as well.
Don't worry about the uppers too much, they rarely give any problems with leaks.
Kurt |
you're done.
i used 600 on mine.
one other thing. take a die and go over all the studs. it will really help in torquing the valve covers. it takes time, but worth it.
Don't the scratch marks INCREASE the risk of leaking??? Those seem somewhat rough. Or, do you polish it now?
a nice belt sanding table takes just a minute or so, compared with doing it by hand. 220 is mighty fine and time consuming. 80 works great and the surface is still smooth.
porsher
Try moving the cover in a figure of 8 pattern, the random nature of the lines will give you a better surface.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Go to Home Depot and get sandpaper for floor sanders, you can get 12x18 sheets.
Spray tack it down to something flat. Throw some diesel on there as a lubricant and have at it. Done.
Tru6 Restoration & Design |
6 cylinder symphony
Silicon valve cover gaskets - from our host.
I installed them a few years ago. Didn't do any sanding on the valve covers. No leaks.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
I was wondering about all the fuss of getting a piece of granite etc...
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Banned
just use some thick plate glass
