1977 911S
What Needs to be Done to a 915 Tranny that has sat for 18+ Years?
Hi Guys I have a 915 Transmission that has been in my Car in a Garage that has not been run or driven in 18+ Years. I have some other threads posted on this.
I am working on getting the car road worthy again and My question is there any kind of Service/Maintenance that needs to be done to the Transmission after sitting for so long? i.e. Changing Fluid etc? Any insight, opinions, and/or help with this is greatly appreciated! Thanks! Regards... |
I would imagine that a fluid change and a visual inspection would suffice.
I am sure the experts will follow up shortly.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
If it was good when it went into storage it should be fine now. If it were me I'd put in new seals on the shift rod, input shaft, and output flanges.
-Andy
72 Carrera RS replica, Spec 911 racer |
Gary R. |
1977 911S
Thanks guys I really appreciate the feedback so far! Any recommendations on what Transmission Fluid to Use? Swepco 201?
Kendall 80w/90 GL-5 DINO oil. If you have LSD you will also need a friction modifier.
Keep the Shiny Side UP! Pete Z. |
1977 911S
Hi Peter Thanks! Did the LSD come stock on a 1977 911S? How do I tell if I have one? Time for some more research!
LOL! It's easy if you can lift the rear of the car so both wheels clear the floor. Do that, release the e-brake, engine off, in neutral, and turn the RR wheel/tire forward. If the LR wheel/tire turns the same (forward) direction, you have LSD, if the LR wheel turns opposite the RR, you do not have LSD. LSD was always a pretty rare option, but back in '77 it was almost unheard of.
the serial number on the bottom tells if it has a limited slip from the factory aswell. I forget the code. I would think youd have more of a chance of the clutch being bad than anything with the tranny itself. But no sence pulling it out till you try it.
82 SC , 72 914 |
1977 911S
Hi Pete thanks again for all your help! I did as you suggested and this appears to be a non LSD Tranny. So just go with the "Kendall 80w/90 GL-5 DINO oil" and no "Friction Modifier" then?
gearhead
1977 911S
Is this the right "Kendall 80w/90 GL-5 DINO oil" just want to make sure I find what you are recommending:
Kendall 1043927 NS-MP Hypoid 80W90 Gear Lubricant - 1 Quart, (Pack of 12) : Amazon.com : Automotive Here is another link as well: Phillips 66 Lubricants: World-class products and services Thanks! Last edited by FxAffPro; 11-02-2013 at 09:35 AM.. |
1977 911S
Hi Matt Thanks I will double check this as well.
What you have to do to it depends on what (if anything) was wrong with it when it was parked. Otherwise, blow a space heater directly on it for a couple of hours to warm it up and drop the oil. Replace with Swepco and yer ready to go.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
