-   -   Hello anybody rebuilt 74 to 77 Turbo or S front calipers? (http://forums.pelicanparts.com/porsche-911-technical-forum/779772-hello-anybody-rebuilt-74-77-turbo-s-front-calipers.html)
Carguy59 11-03-2013 06:13 PM
Anybody rebuilt 74 to 77 Turbo or S aluminium calipers? All the rebuild kits show two seals and two piston boot covers. This ATE caliper has a plate with 4 bolts holding it on, where the brake line threads into. I don't see the seal for that in the kit. Help! Photo of my 1975 911S Widebody kit.
http://forums.pelicanparts.com/uploa...1383531090.jpg
poorsha 11-03-2013 06:32 PM
You might want to show a pic of the calliper instead of the car :)
I rebuilt S callipers and I did not replace that seal (this was many years ago in another life).
Dont know if this helps or not.
Carguy59 11-03-2013 07:11 PM
Well po broke off one of those bolts, so weeps brake fluid. To fix it I need that seal!
fanaudical 11-03-2013 07:19 PM
When I pulled my S-calipers apart I found corrosion and other issues. I priced new pistons, seals, hardware, anodizing, etc and determined it was a good deal to send them to PMB Performane for rebuild. (I never did find that seal that you're looking for.) They came back great!
Charles Freeborn 11-03-2013 07:21 PM
Put all the parts in a box and send them to Eric Shea @ PMB.
You can thank me later.
-C
Carguy59 11-03-2013 07:42 PM
I'd like to, unfortunately I'm disabled and on a fixed income, so if I can fix it with a kit, I will do that.
poorsha 11-03-2013 07:56 PM
Sell the car :)
Carguy59 11-03-2013 08:19 PM
I like it, why would I sell it?
Charles Freeborn 11-03-2013 08:34 PM
Fixed budget, brakes, and Porsche are three terms that don't usually go well together.
Still call Eric. He can steer you to the right parts.
-C
Carguy59 11-03-2013 09:56 PM
Thank you for that sage advice, will definitely try Eric.
manbridge 74 11-04-2013 06:43 AM
I believe Stoddard sells the seal.
If you have a lot of pitting on your pistons your rebuild will not last long which is why people suggest PMB.. They do excellent work.
Carguy59 11-04-2013 08:48 AM
Zero pitting, they look great except for broken off bolt.
manbridge 74 11-04-2013 09:05 AM
I believe this is it...
http://www.*************/911-1965-75/brakes/calipers/sic-351-999-00.html
Take your caliper to a machine shop if you've no experience removing broken bolts with heat and extractor, etc.
Carguy59 11-04-2013 12:16 PM
Jeff, link doesn't work with my tablet, I'll try on PC. Yeah, I'll take it to a shop, don't have a vice to hold it steady or I'd do it. 37 years in the oil & gas industry, 4 of those years as mechanic, technician. From weed wacker to 20 cylinder EMDs,10,000 horsepower GE gas turbins, and nearly everything in between. I'm down to 22 vehicles from a high of 28. I became disabled and have had to sell some cars. Sold 80 Ferrari 400 gt, 69 vette, 65 MB 230 SL, 944 Turbo, 356 Speedster kit,
, 88 Lotus Turbo Esprit, 68 Cougar, 39 Mercury Sport Coupe, oh wait still a partner in that, so as you can see it's not a slippery slope for me, I'm seriously addicted. Thanks again,
Neal
manbridge 74 11-04-2013 12:56 PM
Bad link... try here.
EDIT: Won't let me post it. Go to Stoddard's site and search "caliper end cap seal." Should end in the last 8 numbers above..............
I'd strongly recommend ATE silicone brake paste or equivalent on reassembly.
Carguy59 11-04-2013 01:45 PM
Awesome Jeff, you da man! Only one to show that seal. I bookmarked the page, and will order the part. Thanks!!!!
Neal
