Noob needs Help
Need some help with what looked to me like a simple problem...but I'm clueless as to best way to fix this right the first time. Any help/hints appreciated. Does it require a special screw to re-attach? Is there a best way to attach the edge of the carpet that runs along the bottom edge of the pocket? Thanks in advance.
http://forums.pelicanparts.com/uploa...1383583417.jpg |
Remove black block with screw that is in the direction of the white horizontal line (In the pic)
Find a screw that will bite into the door hole and has a head that fits in the big hole of the block. Screw the block to the door first. Here is that screw if you want to order it: Big screw is 900 143 046 07 "Tapping Screw B 4,8 X 19" (Vertical line in pic) 999 591 103 17 - washer between bottom of door screw head and carpet/panel 900 269 058 07 is screw for the bottom of the doors - 3 per side thru 84. "Countersunk-head screw M4 X 25" http://forums.pelicanparts.com/uploa...1383587796.jpg |
Thanks...ordered just now. Finally a safe place for my coffee cup again. Appreciate the quick response.
The above instructions are perfect. I did this fix about a month ago. The detached and hanging pocket on my driver's side would bug the **** out of me every time I opened and closed the door. The few dollars that I spent on the screws and black mounting block made a big difference in the car's appearance to me.
If you don't already have it, I came across a PDF on this site of the parts catalog with diagrams, for the 1984 - 1986 Carreras. I found that catalog to be very helpful for such projects. |
Funny ... Bugged the #%^* out of me too!
| All times are GMT -8. The time now is 09:34 AM. |
