afishkind's Avatar
Noob needs Help
Need some help with what looked to me like a simple problem...but I'm clueless as to best way to fix this right the first time. Any help/hints appreciated. Does it require a special screw to re-attach? Is there a best way to attach the edge of the carpet that runs along the bottom edge of the pocket? Thanks in advance.
1984 Carrera Coupe...Follow the Wad!
Per Dante: The darkest places in hell are reserved for those who maintain their neutrality in times of moral crisis.
Old 11-04-2013, 08:44 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Remove black block with screw that is in the direction of the white horizontal line (In the pic)
Find a screw that will bite into the door hole and has a head that fits in the big hole of the block. Screw the block to the door first.
Here is that screw if you want to order it:
Big screw is 900 143 046 07 "Tapping Screw B 4,8 X 19" (Vertical line in pic)
999 591 103 17 - washer between bottom of door screw head and carpet/panel
900 269 058 07 is screw for the bottom of the doors - 3 per side thru 84. "Countersunk-head screw M4 X 25"
1981 911SC Targa
Old 11-04-2013, 09:57 AM
afishkind's Avatar
Thanks...ordered just now. Finally a safe place for my coffee cup again. Appreciate the quick response.
Old 11-04-2013, 10:18 AM
The above instructions are perfect. I did this fix about a month ago. The detached and hanging pocket on my driver's side would bug the **** out of me every time I opened and closed the door. The few dollars that I spent on the screws and black mounting block made a big difference in the car's appearance to me.
If you don't already have it, I came across a PDF on this site of the parts catalog with diagrams, for the 1984 - 1986 Carreras. I found that catalog to be very helpful for such projects.
Old 11-04-2013, 11:09 AM
afishkind's Avatar
Funny ... Bugged the #%^* out of me too!
Old 11-05-2013, 05:21 AM
