1987 Carrera
Easy question
How to you clean the copper connections? Metal brush?
Ace123
1987 Porsche 911 Coupe
Old 11-11-2013, 08:05 AM
ROW '78 911 Targa
timmy2's Avatar
For electrical connections?
If they are green with corrosion use a bit of vinegar on a brush to remove then rinse with water. Then some fine Emory cloth or sandpaper to polish.
A fine stainless brush will work as well. Make sure the battery is disconnected.
Old 11-11-2013, 08:23 AM
Diss Member
Quicksilver's Avatar
If you use an acid I would neutralize it...
Bigger thing for long life is to use some dielectric grease to seal and protect the connection.
As to the original question: Clean what copper? More detail gives better answers.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-11-2013, 08:33 AM
Functionista
manbridge 74's Avatar
+1 on dielectric grease.
Connections aren't exactly of the weather pack style (used on all makes today) on these old birds.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-11-2013, 08:40 AM
ROW '78 911 Targa
timmy2's Avatar
Yes, as others have suggested, dielectric grease in a light film applied after cleaning is a good thing.
(Assuming we are talking electrical connections) ......
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-11-2013, 09:02 AM
1987 Carrera
Yeah, copper electrical connections such as for the fuses or the tab connections for electrical wiring.
Ace123
Old 11-11-2013, 11:16 AM
1987 Carrera
So vinegar, stainless steel brush and then some dielectric grease. Sounds good! Thanks!
Ace123
Old 11-11-2013, 11:19 AM
frannyB's Avatar
Hi Ace,
I used a brass wire wheel on my Dremel and that did the trick very well. I pulled all the fuses and did the box connections and the fuses themselves. Don't forget the couple-three in the engine compartment...
Franny
White '86 Carrera Cab "Shamu"
Old 11-11-2013, 11:45 AM
1987 Carrera
Interesting. I have a dremmel, but not the brass wire wheel. I bet it cleans up nicely. Home depot for the wire wheel? How about HF?
Ace123
Old 11-11-2013, 12:00 PM
frannyB's Avatar
Or just about any hobby store... I bet HF has them too. I think I got a big assortment at Costco some years back and I'm due for another. I used the brass wheel so as not to be too rough on the contacts and not add a completely dissimilar metal.
There are sooo many connection points on the car with lots of grounds. I pull them and clean them as I find them. I'm not a fan of electrical issues
Franny
Old 11-11-2013, 12:05 PM
1987 Carrera
I looked for the brass wheel at HD and couldn't find it. I ended up with a "Finishing Abrasive Buff". It looks like it will work well on the fuses. I got an Volt meter as well. I think I over bought on that one. It does a bunch of stuff ~$50.
Ace123
Old 11-11-2013, 01:21 PM
Bill
By far these are the absolute best things for cleaning electrical connections for any kind of car. I've been using them on my motorcycles for a long time and recently ordered some more refills. Be careful that the little bits of fiberglass don't get in your fingers as they can cause problems.
Fiberglass Pen
Old 11-11-2013, 01:32 PM
I disagree on the dielectric grease. this grease is a barrier to electrical transmission, look it up on wikipedia. Use some wd40 or other corrosion protection lubricants.
I used dielectric on some bulb contacts and could never get a good connection.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-11-2013, 02:45 PM
AutoBahned
RWebb's Avatar
Originally Posted by ace123 View Post
So [10%] vinegar, [brass] or stainless steel brush and [then some DeOxIt sprayed on the connection; then the] dielectric grease. Sounds good! Thanks!
also rotate the fuses while hosing them down with DeOxIt every so often
dielectric grease will be squeezed out from the contact areas; you use a very thin film - for more, search on those two terms and carefully read the comments from the late Jim Sims, an expert on such issues (according to the DOE)
Old 11-11-2013, 03:41 PM
