Jayboundless's Avatar
Vacuum Leaks - tutorial needed
Hello Pelicanites, I am wondering if someone can provide a comprehensive tutorial/ verbal diagram of all possible culprits of a vacuum leak on a 3.2 engine. It seems there are only very fragmented descriptions and suggestions posted on this topic in response to multiple engine problems. Wouldn't it be nice to have one source for this information?! Or maybe this exists somewhere and you can point me to it.
Thanks much in advance!
Jay B.
Old 11-05-2013, 06:41 AM
frannyB's Avatar
I'd be interested in that as well
Franny
White '86 Carrera Cab "Shamu"
Old 11-05-2013, 07:21 AM
well no diagram, but for a 3.2 certainly check:
power brake contraption
vacuum lines for fuel dampner/pressure regulator
intake runners
fuel injector o-rings
pcv valve
oil cap
idle bypass screw o-ring
Basically everywhere there is a hose connected to the intake!
Chuck.H
'89 TurboLookTarga, 365k miles
Old 11-05-2013, 07:56 AM
vacuum leaks
Were you having an idle problem? My idle is acting up and I was about to start following the recommendation for looking for vacuum leaks, but had no idea where to start.
Old 11-18-2013, 09:11 AM
kodioneill's Avatar
Intake runners as stated above, the intake to head gaskets disintegrate.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-18-2013, 10:37 AM
