Fog light adjustment on an 87
Not sure how to adjust my fog lights on my 87, anyone have any hints
They are in a FIXED position. Low and wide beam pattern.
they appear to just throw the light no more than 5 feet from the bumper
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fog Lights.
They are only adjustable left to right, not up and down.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I'm running H4's on my '87. The fog lights only serve to sweep the yellow line and the center line. They're not really fog lights, they just light up a wider part of the road. Still they're good for running the two lanes in the night paricularly if there's wildlife around.
Looks like I'll have to come up with a solution... Will keep you updated with results
how I adjust the headlights? I have many problems to be centralized both sides in low light and high beam
Rescuer of old cars
If your '87 still has the original US market H5 lights, they aren't all that great. You may want to consider converting to H4s if you drive much at night.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
h4 6000k on my 84 have it but I neeed to adjust them when y centralizing well
How do you make this adjustment? My one fog light is cocked outward.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Go-Kart Mozart
Look or feel behind the valance along the midline of the fog lamp. The fog lamp body/bracket has a stud that points down and through the fog lamp mount bracket on the valance. You should see a 15mm or 17mm nut. Loosen a little, adjust fog lamp, re-tighten. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Go-Kart Mozart
If you have H4s there will be three screws on the mounting ring. One at the bottom that mounts the light to the car. The two others one low and one opposite and high are for adjustment. One for horizontal and the other for vertical. I can't remember which is which but you'll see the change if you shine the lights on a wall. If you only see one screw at the bottom then you have trim rings installed over the mount rings. Remove the bottom screw and carefully remove the trim ring. You should see the two adjustment screws. There is a good set of directions for aiming your lights on the Daniel Stern website. -J
