SWB adjustable spring plates and alignment
I began a new project this weekend; I'm modifying my shortened 911SC spring plates to have a screw adjustor like Sway Away no longer makes. I'm also beginning a four wheel alignment and corner balance using the corner scales and simple string alignment aid I made and will be marketing shortly; more on that later.
I first removed rear shocks and installed my height adjusting rods: http://forums.pelicanparts.com/uploa...1384128461.jpg I also disconnected my front sway bar drop links and connected them to the brackets on my inner wheel well: http://forums.pelicanparts.com/uploa...1384128580.jpg I adjusted rear ride height while supporting front cross member to avoid corner weight bias: http://forums.pelicanparts.com/uploa...1384128680.jpg Made a CAD drawing and templates for modifying the spring plates: http://forums.pelicanparts.com/uploa...1384128799.jpg And: http://forums.pelicanparts.com/uploa...1384129325.jpg Photo of brackets aligned on spring plates ready for welding: http://forums.pelicanparts.com/uploa...1384129396.jpg That's all for today. |
Nice springplates! I love DIYSmileWavy
LOVE these on my '66 912.
Took some grinding of the screw mount and the lug it presses on to make 205's not rub. http://i70.photobucket.com/albums/i1...pscbc3127c.jpg I can send pic of the grinding if needed. I can also measure it too. |
Hi Jon,
I think I'm good, I checked tire clearance before I removed for the surgery. Running 225/50-15's on 7Rs with spacers. |
Paul how did these finish up?
I installed and adjusted my car using these just fine. I need to make one more iteration in ride height that is beyond the range of adjustment but haven't gotten there yet.
BTW how are you using the height adjust rods
I used the rigid links to adjust ride height and alignment and then installed t-bars and adjusted to just take the load ff the links.
I made the links for use in assembly and other tasks during my build as a convenience to hold the car at ride height while working on it...this is primarily why I had the links in the first place. |
Paul, can you provide some details for your mod??
Thickness of ne blocks? Bolt size and threads? A PDF of the drawing of the plate for modifications?? I know it's asking a lot be we want to perform this mod on our project car and love the DIY aspect. |
Contact me via m business email and I can get drawings to you. Performance Oriented
Paul - those ride height links look like just the thing for locking the suspension and figuring out the center of gravity.
| All times are GMT -8. The time now is 10:19 PM. |
