Ferrino's Avatar
Front Rotor Fasteners
I'm replacing the fasteners on my 911 front rotors (20mm rotors on a '76 911) and the old ones are composed of a M8x22mm bolt, with a spring washer and a regular M8 nut. I just wanted to double-check these are supposed to be plain M8 nuts and not the locking variety? They are NLA from Porsche/Pelican and I want to make sure I get the right replacements from the hardware store. Would it be wise to use locking nuts anyway? Thanks!
Old 11-11-2013, 11:23 AM
I am sure you would be fine using a nylock. Overkill, but safe nonetheless.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-11-2013, 11:33 AM
GaryR's Avatar
Send a message via ICQ to GaryR
In a street car nylock will most likely be fine, too much heat there for my car, serrated schnorr washers and flat nuts for me.
Gary R.
Old 11-11-2013, 11:41 AM
Ferrino's Avatar
Thanks all. My local hardware store has some Class 10 conical locking nuts, so i will probably go with those:
Old 11-11-2013, 11:50 AM
GaryR's Avatar
Those should work, dab of never seize can't hurt either..
Gary R.
Old 11-11-2013, 11:56 AM
