911 experts.. I need your help identifying some random parts
So I just bought a 1987 911 from a fellow pelican member which was turned into a track only car which means the entire interior was pulled out along with the AC system and every bit of the heating system. I'm in the process of putting things back together but a lot of the parts I received are not labeled so I'm have trouble identifying what part goes where. I've already identified quite a few parts with their part numbers however there a quite a few pieces that don't have part numbers. I've included some pictures of the parts in question and I've also placed a US Quarter in some pictures to help you gauge the size of the parts. Any help would be appreciated.
1983 Porsche 944 (Sold), 1986 Porsche 944 N/A (parts car), 1987 Porsche 944 Turbo (Sold), Mercedes ML55, 2011 BMW 328i X-Drive, 1987 Porsche 944 and a 1987 Porsche 911 Carrera
Old 11-11-2013, 10:01 PM
Actually I think i've ID'd 2 of the parts in the last picture. I think the rectangular rubber piece on the right is for the AC duct located next to the jack in the trunk and the black piece directly to the left of it I assume is a battery bracket.
Old 11-11-2013, 10:04 PM
The other two pieces in the bottom photo are oil line brackets. You would have a thin piece of rubber (think bike inner tube) around the line where the bracket touches it. One is definitely under the right rear fender between the oil thermostat and the engine.
Old 11-11-2013, 10:17 PM
Bill Douglas's Avatar
Yup, the moustache looking bit of metal is for holding the oil lines up.
Old 11-11-2013, 10:30 PM
Pic no 2 looks like catalytic converter heat shield.
Upperleft thingy on last picture is bracket for holding radio from behind.
Old 11-12-2013, 03:31 AM
Flat Six
Flat Six's Avatar
Pic 2: Cat shield
Pic 3: Brake caliper pistons (pretty sure)
Pic 7: 2nd from right is passenger floor board hold-down
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 11-12-2013, 07:17 AM
Last picture middle, looks like the battery hold-down piece.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-12-2013, 07:21 AM
Pic #1 looks like roll bar cushioning.
94 turbo 3.6
74 carrera RS race car
05 denali XL
"We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski
Old 11-12-2013, 07:25 AM
Picture 4 is for holding the heat shield to to the Cat. Picture 1 is looking like a roll-bar cushion. Picture five, upper right is the hold-down for the oil lines inside the right-rear fender.
Old 11-12-2013, 07:37 AM
Is picture three brake caliper pistons? I do not see any indentation for the seals, which leads me to believe that these are oil thermostat inserts.
Originally Posted by Flat Six View Post
Pic 2: Cat shield
Old 11-12-2013, 07:44 AM
group911@aol.co's Avatar
Looks like cut off pieces of early bumper or rocker deco strips
Cat convertor heat shield
Bracket for cat heat shield
Top right is oil line clamp. Bottom 2 are brackets to hold door top trim in place- 86 to 94? parts
Bracket from cowl to trunk in front of blower assembly
Upper left- radio bracket. Oil line clamps below that, battery hold down to the right and gasket for front a/c blower on the far right.
Thanks,
Bob
group911@aol.com
Old 11-12-2013, 08:21 AM
You guys are awesome! Thanks a lot! If I find more pieces that I'm not sure about, I'll post them here.
Old 11-12-2013, 08:44 AM
