-   -   need setup info for track/autox (http://forums.pelicanparts.com/porsche-911-technical-forum/78146-need-setup-info-track-autox.html)
ssoar 08-20-2002 04:29 PM
Hi, I've got a dead '76 911 I'm resurrecting as an autox/track day car. Initially I'm going to go with the stock motor (cause its what I've got) and tweak the suspension. My plan:
22mm F 28mm R torsion bars
sway bars off a '77 930
adjustable spring plates
poly bushings everywhere
thinking about the koni yellow adjustable shocks, anybody have a better sugestion?
16x7F, 16X8 or 9 R wheels, with carrera flares on the rear.
What suspension settings are recommended?
I've heard:
as much camber as possible in front (~1.5deg), 1/8" toe in
~2.5deg camber in the rear with 1/16" toe in
lower the car until the F roll center is on the ground, and preserve the front downwards rake
thanks for any info!
-steve
StuttgartDavid 08-20-2002 11:39 PM
Your parts and alignment specs sound dead on for a track car. For autocross use, you may want to try front toe out (yes, toe out!) for quick turn in. However, don't try that for a big track with 3 digit speeds!
Also, for a set up like that, Bilstein sports are great, and won't let you waste your time messing with shock adjustments.
