Any tricks to tighten up distributor cap?
Changing the ignition parts on a 70 914-6. Original distributor has the older style spring steel clips to hold the cap and the clamps are real loose. Seems like these all run loose (have a few spares). Thinking about slipping something over the claw that grips the cap to tighten the hold. Anyone have a similar or different solution? Any input would be appreciated. Thx
Old 11-14-2013, 08:20 PM
On our rally car, we place a cable tie around the clips.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 11-14-2013, 08:37 PM
Actually, I just bend mind abit in a tight bow shape and that's add the tension to hold it down. Simple enough.
Old 11-15-2013, 09:12 AM
+1 on what sunroof said. Just add a little bit more bow to the clip, works like a charm. I just used a pair of pliers to bend down the top clamp part of the clip, which added a little more bow to the clip. It didn't take much.
Craig
77 Ice Green 911s w/3.0
Old 11-15-2013, 12:11 PM
