1980SCMan
Alan Lindquist's Avatar
Harbor Freight Fuel Pressure Testing Kit - Need Help Please
1980 SC - I'm confident that I've resolved vacuum leaks and am now ready to test fuel pressure. I have good resources (from this forum) on how to test, but I'm stuck at how to hook this kit up. If someone has used this kit, they'd know which pieces they selected to make the proper junction.
The tray lifts off and the main hose is available. The kit's instructions lists the possible pieces for CIS connections, but so far I can only determine that I can remove the nipple fitting at the WUR and securely join there. I can not figure out how to get the other end of the hose to mate with the FD, or with the end of the line coming from the FD.
Has anyone successfully used this kit and can they tell me which fittings they used? The fittings are numbered, or a photo that they may have taken in the process would be helpful. I'd be grateful for a few tips.
Old 11-15-2013, 09:32 AM
kodioneill's Avatar
Check the search function there's a thread on that very gauge with the proper hose hook up and all.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-15-2013, 10:38 AM
kodioneill's Avatar
Here it is:
HF CIS Pressure Guage
1982 chiffon 911sc
Old 11-15-2013, 10:39 AM
Brew Master
cabmandone's Avatar
I've got a 3.2 so I'm not going to be much help unless you have the fuel rail plug like my car did. I used a R134 to R12 adapter fitting which happened to be the same thread as my fuel rail plug. Then I just connected the hose.
Old 11-15-2013, 10:41 AM
kodioneill's Avatar
You want to hook it up in line with the top center fuel line from the fuel dist to the WUR. Or substitute it for the entire line to check your control pressure.
1982 chiffon 911sc
Charles Freeborn's Avatar
I picked up the same rig while the 25% off coupon was (maybe still is) in effect.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-15-2013, 12:06 PM
ASE Master
alfadoc's Avatar
There's a HF 25% off coupon every month in Popular Mechanics, Motor Trend, Rod & Custom, etc. I always hit the magazine rack before a trip to HF.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 11-15-2013, 12:18 PM
Bill
Same one I used for mine,
You have to use the hose in the bottom of the kit with the stop valve. It replaces the hose that goes from the Fuel Distributor to the In Fitting on the WUR. The stop valve goes on the WUR side so you can isolate the WUR when testing system pressure. I had to try different fittings until I got the ones to work. I also removed the silly little air stop valves in the fittings too.
Old 11-15-2013, 01:04 PM
1980SCMan
Originally Posted by kodioneill View Post
Thanks. That's what I'm looking for. I see my problem now. I was using a female fitting to the male fitting threaded into the WUR when I needed to pull that male fitting and run a male fitting from the kit in there. That free's up the female fitting for the FD.
Sweet. Much appreciated.
Old 11-15-2013, 02:40 PM
