Aerial 911 SC
Hi folks what's the best way to remove the aerial on an SC to then allow the wing to be removed. Having trouble and don't want to break anything or chip paint.
Thanks very much
Old 12-17-2013, 10:06 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
im not sure what an aerial is? could you post a pic? thanks.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-17-2013, 11:28 AM
Think antenna.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-17-2013, 11:51 AM
Diss Member
Quicksilver's Avatar
Antenna
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-17-2013, 11:52 AM
kodioneill's Avatar
antenna = aerial wing = fender
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-17-2013, 11:53 AM
Unscrews at the top flange and the aereal drops down through the wing/fender whatever
Old 12-17-2013, 12:36 PM
Sorry gents , I usually get my terms right. Antenna and fender yes. Thanks for all your help with this.
Old 12-17-2013, 03:46 PM
Fb = M/S
aoncurly's Avatar
1981 911SC Manual Antenna Replacement
If you have the manual antenna on a 911SC, it is a royal pain because it is sandwiched between the door jamb and gas filler neck. See the link above.
I think the only way is to remove to door. I ended up taking my car into a shop.
Old 12-17-2013, 04:23 PM
Banned but not out, yet..
RSBob's Avatar
There may be a secondary point of attachment for the areal to the firewall, usually secured by a screw. It is not difficult to remove.
Old 12-17-2013, 06:48 PM
Cooper911SC's Avatar
Are you removing the aerial from a left or right wing?
Typically the power aerials are mounted on RS and manual on LS.
In both cases start by removing the escutcheon nut on top of the aerial. You need either a special spanner or I use very small needle nose pliers.
If it's the left side you're working on the next step is to remove the door from the car.
The easiest way is to pull the hinge pins with a slide hammer.
You will need to remove/unplug the wiring harness for power wimdow and mirror. Also door speaker.
Once the door is off, remove the lower fastening screw for the antenna support.
Unplug the coax lead and feed out the wire.
R side is easier. Loosen the lower mounting fastener/bracket. Unplug
The antenna coax lead as well as the power/ground leads. Feed them out and remove the antenna.
Hope this helps!
Cooper
Old 12-17-2013, 10:29 PM
Remove the upper nuts on the antenna and then remove the fender. I see no reason to remove the antenna first, or to remove the door at all.
JR
Old 12-18-2013, 05:04 AM
Thanks for all the help. Just to close this it was bolt on the top and then the aerial came through the fender underneath.
Old 01-06-2014, 11:52 AM
