Jacking with engine removed
Any suggestions how to safely jack up the rear of an SC once the engine/transmission are removed?
Once I've dropped the engine I want to drop it back onto its' wheels so that I can push it outside to pressure wash the engine bay. Then, obviously I've got to jack it back up to re-install the engine at a later date. I'm not keen on using the side jacking points as it needs to be raised to a considerable height to get it back on axle stands in order to re-install the engine/transmission. |
I use a section of 2X6 spanning the back edge of the pan, just forward of the torsion tube.
HTH Thor http://forums.pelicanparts.com/uploa...1385113319.jpghttp://forums.pelicanparts.com/uploa...1385113472.jpg |
Thanks,
I thought this might be the solution but was worried about floorpan strength. |
Your quite right, it'll be a few 100kgs lighter for sure.
Thanks. |
You can simply put one side down first and then the other.
| All times are GMT -8. The time now is 12:49 PM. |
