Jacking with engine removed
Any suggestions how to safely jack up the rear of an SC once the engine/transmission are removed?
Once I've dropped the engine I want to drop it back onto its' wheels so that I can push it outside to pressure wash the engine bay. Then, obviously I've got to jack it back up to re-install the engine at a later date. I'm not keen on using the side jacking points as it needs to be raised to a considerable height to get it back on axle stands in order to re-install the engine/transmission. |
I use a section of 2X6 spanning the back edge of the pan, just forward of the torsion tube.
HTH Thor ![]()
1978 SC coupe #1834 Last edited by Brown747; 11-22-2013 at 01:50 AM.. |
Thanks,
I thought this might be the solution but was worried about floorpan strength. |
I did the same as Thor. The drivetrain represents a major % of the total weight of the car, and it's now gone. So there is a lot less stress placed in that area when they are gone. Using the 2x6 helps distribute that stress evenly over a larger area.
Your quite right, it'll be a few 100kgs lighter for sure.
Thanks. |
Undocumented User
You can simply put one side down first and then the other.
83 911 Production Cab #10
Around 600 Lbs
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
