turbo dave's Avatar
Question Brake Pad Change-help!
I'm in the process of replacing brake pads on my '73, and the new pads seem very tight going in the calipers. Also, the pads rub on the rotor pretty tightly- I can turn the rotors, but it takes a ton of effort. Will this loosen up when I put the retaining springs & pins back, and drive it for a bit?
The pads are Hawk PBS street/track, on M calipers. Thanks in advance-
Old 09-03-2001, 09:01 PM
Send a message via AIM to 82SC
Post
everything is fine...
the pads should almost ride on the rotors...should not be able to see light through the pad/rotor interface...
Old 09-03-2001, 10:23 PM
Post
Drive it a bit and see if the problem remains.
A slight sticking is quite normal, although with my all-new calippers I was able to turn all wheels absolutely free just with my fingertips.
Jens
Old 09-04-2001, 12:23 AM
turbo dave's Avatar
Post
Great, thanks for the advice-
Old 09-04-2001, 11:04 AM
