****#x!*!Suspension Squeaks!
'87 Targa
Suspension squeaks are driving me nuts. Coming from the front. I've used a good quality spray lubricant on the sway bar bushings. Still squeaking. I can even get the squeaks to occur when I open and close the drivers door with the car parked in the garage. (Squeaks coming from the front suspension - not the door.) What else / where else should I be looking to get at these varmints?!? |
Front control arm bushings? Mine squeak. It's a project for this winter.
well? it is probably your torsion bar cap..it rubs against the alu.suspension piece..
here
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Car has over ~120K miles, and lots and lots of track use. I'm pretty confident they have been replaced, likely more than once at this point. |
yes......prior the replacement you can just lube this bottom part.. remember how many turns you do on the adjusting screw-mark it..
Ivan
What materials are you running in the bushings? Stock rubber? Polyurethane seems to squeak regardless of what you do...
I slipped a small metal shim under the torsion bar cap and the annoying squeak stopped. Also plan to replace bushings.
You can't lube your way out of this problem. Well, maybe for a few miles.
I went Elephant Racing poly bronze 15 years ago. The front is easy DIY & you can do the rod ends & ball joints & service the steering rack "while you're there." Otherwise will go forth to eternity sounding like a Conestoga wagon rolling over the prairie. |
Well, it's not the torsion bar cap. Dagnab it.
I'll get this addressed one way or another. |
If not the cap most likely the bushing is worn and the torsion bar itself is rubbing -by now it lost its coating...before the big job, again you can remove the cap and slide out the bar .On the bottom you will see the shiny place where it rubs....apply some grease there...always remember where the adjusting screw was.....
Ivan
When the bushings wear the torsion bar rubs in the back of the A arm. Pull the front T bars out a couple of inches and u might see the paint rubbed off the bar, dry and maybe rusty. Grease it, reinstall and see if noise is gone. Of coarse the bushings are still worn out.
The car has low mileage - less than 20k on it. (All indicators on the physical car, as well as service documents etc suggest that this mileage is accurate.)
So based on that, it's hard to believe that the bushings could be worn out. Certainly the rubber has aged with time - no question about that. The seller that I purchased it from had the undercarriage dry ice blasted. Perhaps that had some affect on creating some of the creaking - I don't know. Colder temps here are no-doubt exacerbating the issue. The car drives / handles just great - no issues. But the squeaks are getting to me... |
well ,next time start with this info that would help...also make a sound recording of the noise or video ..that would help too;-)Does the noise come when you push on the fender? try each side..or not?
Ivan
PRO Motorsports
It’s not about mileage, but also age. The front bushings are a pretty soft rubber. The bushings near the torsion bar adjust are taking all the force is the torsion bar springing. The heavier later cars have it the worst.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
When I push down on the driver's side front fender I can hear the squeak. On the passenger side, when I do the same thing - no squeak. |
