Banned
no state or local emissions here. remove cat during exhaust repair?
Heater boxes rusted out so I'm gonna be swapping out some parts. ssi or early h-e and better sounding muffler. Car is 3.0 in an SC and my big question is it good or bad to remove the cat and run a bypass pipe? Thx for any help. Also what's a cheap pipe worth?
Old 11-25-2013, 01:35 PM
That's what I did on the 3.2. M&K pre-muff with O2 sensor. Works great.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 11-25-2013, 01:54 PM
neither the ssis nor the early headers/heat exchangers have an interface for a cat, so you won't need to worry about a cat or a bypass pipe (or a european pre muffler) if you go that route.
Old 11-25-2013, 02:30 PM
Eva
911SauCy's Avatar
Ditch the cat.
I did, car sounds great, runs great, and lost weight.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-25-2013, 02:32 PM
remove cat?
Yes, Yes Yes and install Headers with a bung for the O2 sensor and a muffler. Mine are headers by George Narbel and Muffler by Triad. It has a deep throat, not raspy, and not too loud. Paint is by Jet Hot Coating.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 11-25-2013, 02:39 PM
you see Arthur...
jasonlee's Avatar
i removed my cat and installed a bypass on my SC, have an O2 sensor for when when I need to tune to pass smog here in Vancouver. Runs great and sounds great
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 11-25-2013, 02:47 PM
718 718 is offline
Banned
A 3.2 should be retuned (chipped). How do you do that with CIS?
Old 11-25-2013, 02:52 PM
Senior Advisor
James Brown's Avatar
no chip in the CIS but the can be optimized with a engine exhaust analyzer for fuel/air settings, thats about all you can do. And ensure the cold start circuit pressures are correct
08 Cayenne Turbo
Old 11-25-2013, 02:58 PM
Vintage Owner
Jack Stands's Avatar
You might want to read the chapter in Bruce Anderson's book (Porsche 911 Performance Handbook) for information on backdating to the SSI exchangers. It should give the most bang for the buck, and the heat exchangers are works of art.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 11-25-2013, 03:03 PM
Agree completely. Running SSI's w/no O2 sensor on my 83 and although a little quirky at times when it's run time it rocks!
Old 11-25-2013, 03:32 PM
Vintage Owner
If they don't come with one, have an oxygen sensor bung welded in.
84 Targa (sold)
70 914-6 (sold)
2016 Cayenne
Old 11-25-2013, 05:40 PM
