-   -   911sc front sway bar issue (http://forums.pelicanparts.com/porsche-911-technical-forum/783990-911sc-front-sway-bar-issue.html)
mcguireh 11-26-2013 12:11 PM
I have a weltmeister thrubody front sway bar on my 1980 911sc needing new bushings (lots of rattle & noise). My local garage says these sway bars have been discontinued along with replacement bushings. They are recommending going back to the stock sway bar costing about $400-500. Since I don't race and use the car casually I don't need the heaver WM but wish I had other options.
Any suggestions. McG, NC mountains
toddu 11-26-2013 12:17 PM
Tarett is another option, but not any cheaper -
http://www.tarett.com/
Todd
gtc 11-26-2013 12:19 PM
Did you try calling either Pelican or Automotion for replacement bushings?
mcguireh 11-26-2013 12:39 PM
Called both Pelican and automotion. Pelican does not have them, automotion will call back by Friday with answer.
mcguireh 11-26-2013 12:41 PM
Thanks, I'll check them out.
Matt Romanowski 11-26-2013 12:51 PM
Check with Paragon Parts too. If no one has them, you should be able to have something made out of Delrin pretty easy by anyone with a lathe.
GaryR 11-26-2013 12:53 PM
Since you already have through the body holes I would go with Smart Racing sways... or get bushings made up!
Matt Romanowski 11-26-2013 12:54 PM
They don't make the Smart Racing bars anymore, but there is an almost new used one for sale in the forums here.
GaryR 11-26-2013 01:01 PM
So mine are collectors items now!! $$$$
:D
