Madsimilius
G50 shortbell convertion, what clutch and flywheel?
I've just bought a g50/00 for as little as 1800$
![]() Will the spec lightweight flywheel and KEP clutch pressure plate work? The KEP pressure plate seems good and i need a clutch that can handle about 700bhp. Any info about the hydraulic lining and shifter is also very welcome!
911sc, 3.1, ported 40mm, cams and titanium retainers, carrera 3,2 intake, ms3x, k27/k29, full exhaust, |
Schleprock
Stock G50 shifter drops right into the SC, as does the G50 pedal cluster from 87-89 911. You need the shifter, shifter rod and transmission shift shaft coupler.
Clutch that I know works is the low profile early 930 kit from Patrick Motorsports 911 Turbo Carrera - 930 Clutch Set - Centerforce Lightweight KEP makes really nice stuff & Patrick can get you the low profile KEP clutch for the G50 short bell setup http://www.patrickmotorsports.com/manufacturer/kep-KENNEDY-ENGINEERED-PRODUCTS/
Kevin L '86 Carrera "Larry" |
Madsimilius
Ok great ! thnx! Still not sure what flywheel to use ? anyone tried the spec lightweight flywheel? will i gain much from a lightweight? i need a new one anyhow as i have a 225mm now. The cheapest would be buying a used a stock 240mm, but i don't know about that.
Diss Member
I put in the KEP lightweight pressure plate over 10 years ago. Heavier clutch pedal but I think it is well worth it. The light weight really helps the engine RPMs match faster when shifting. Plus you can measure the acceleration difference in 1st and 2nd with a stop watch.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
