Really huge spacers?
Greetings!
I knew there was some funny business going on when I bought this car (82sc), but it was cheap and I needed a new project. As you can see in the following photo, the wheels stuck out quite far:
I finally got the car up in the air to finish the AC tear out (my favorite first task on a sport car). Here are some pics of the biga$$ spacers I found:
The front spacer measures 1 1/8", the rears 2 3/16"!! No wonder the wheels stuck out so bad. My questions are: Is it common to run some sort of spacer? If so what is the preferred size to run, front and rear? The wheels are 7" and 8" Fuchs 16".
Thanks for your replies!!
Carter
Old 12-01-2013, 06:07 AM
No spacers are needed, if you run the correct wheels. Have another look at the wheels and see what sizes you have and what part numbers they are. The fronts look like 6" and I can't tell from the photo what size rears that you have.
JR
Old 12-01-2013, 06:33 AM
If you run 7" and 8" you may don't need any spacers. I run 6" and 7" and use 1/4" spacers in the front and 1" in the back. Try first without the spacers and do an alignment, corner balance and height adjustment. See how you like the look and go from there. Rigth now you can not lower the car without serious rubbing.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 12-01-2013, 06:37 AM
javadog,
Thanks for the reply. Hope all's well in T-Town. I'll be out there for the holidays, around the 20th 'til after new years day.
To answer: I measured the wheels yesterday, and 7" front, 8" rear is what I came up with. I'll go get some numbers today. The wheels are very dirty inside. What was the finish on the inside of the wheels for sc vintage Fuchs'?
Carter
Old 12-01-2013, 06:41 AM
Carter,
The wheels were probably black on the inside. Now they are probably a dark brown from brake dust and that's a ***** to remove.
Most likely you have 6 and 7 inch wheels but I was curious if you might have any 944 wheels on the car. The part numbers will tell all.
JR
Old 12-01-2013, 07:11 AM
Cooper911SC's Avatar
The inner barrels on the Fuchs are painted satin black.
C
Old 12-01-2013, 07:13 AM
pors1968's Avatar
they look like replica 6 and 8x16 normaly no need spacer but what is the offset of these wheels.
Old 12-01-2013, 07:17 AM
pors1968's Avatar
i had look at it twice javadog have right answer
Old 12-01-2013, 07:34 AM
Bill Verburg's Avatar
An Sc/Carrera body car can use oe;
front 6ET 36, 7ET23.3 w/o spacers in 15 or16" these will have 911 or 951 part #s
rear
7ET23.3, 8ET10.6 w/o spacers these will have 911 part #s for the most part but the 7" rears could be 951 too.
aftermarket Fuchs options
front 8ET23.3, 951 wheels, w/o spacer, these are a poor fit in front but have been used they are extremely tight at the lips
rear
9ET15 w/o spacers these are 930 wheels and some even use a small spacer w/ them
8ET23.3 951 wheels will need ~10-12mm spacer in back of an SC/Carrera
The front spacers in the pics appear to be 930.341.611.00 which are used on early 930 front, 21mm thick
the rears may be 930.331.911.04 which were used on 930s, ~54mm
If you can find part #s on the spacers as well as the wheels we can determine what they are, the rear wheels definitely stick out too far
Bill Verburg
Old 12-01-2013, 09:48 AM
Thanks all for the replies.
I checked #s on the wheels yesterday.
Fronts: 6Jx16
Rears: 7Jx16
All have 911 part numbers.
I didn't get numbers off the spacers, but they are all H&R branded. The measurements originally posted for the spacers are accurate. The fronts are more than 1" thick, so 26mm+. The rears are greater than 51mm.
I take it that I'm safe in ditching these, backspace-wise. They're currently soaking in PB Blaster.
Carter
Old 12-02-2013, 04:28 AM
Yes, feel free to get rid of all of the spacers. Not needed.
JR
Old 12-02-2013, 04:37 AM
Fronts: 6Jx16
Rears: 7Jx16
Carter
Yes
A common upgrade is moving the rear 7s to the front w/ 205/50 or 205/55 tires and purchasing 8ET10.6 rears w/ 225/50 tires or 9ET15 rears w/ 245/45 tires, no spacers for any of these.
Bill Verburg
Old 12-02-2013, 05:28 AM
maybe they had later wheels on it and put the old wheels back on it to sell it and couldnt get the spacers off so they just left it
Old 12-02-2013, 05:48 AM
pors1968's Avatar
that i was thinking porsche930dude richard
Old 12-02-2013, 06:25 AM
Model Citizen
herr_oberst's Avatar
Technically, those aren't spacers, those are adapters.
I have 1" hubcentric spacers on the rear of the my 88 Carrera, 8x16 wheels, and to me it is just right. The tire just hugs the radius of the fender with no rub.....
Old 12-02-2013, 06:33 AM
