Hello, New 1981 911SC Targa Owner
Hello Pelican! My name is Mike. I am a newbie to the 911 world. I have had a 1986 944 NA and restored it over the last two years. A gentleman in the local Porsche club asked me to sell an investment property with no room for commission. As a thank you he gave me a 1981 911SC Targa. I learned 944's over a few years from enthusiast but have a lot to learn with this car. What I know about the car is this
150,000 miles New clutch Needs injectors cleaned or replaced Makes a whining noise shifting into second (rubbing noise) Has had the AC deleted which I want to add back. That's about it. I am about to hit the forums now to start learning. Anything anybody wants to share about their experiences with their cars is absolutely welcomed. I have heard they are a bit quirky. Looking forward to learning! ![]()
Hey mike welcome to pelican........ and yes it's me....
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
Looks like I am going to need the Wevo coupler, new bushings, clutch adjustment, and swepco in the gear box to help the 915 train. Does our soccer coach do synchros?
Welcome! I'm a big fan of SC Targas. I'm sure you will have a lot of fun with this one.
How much of your AC was deleted? If it was everything front and rear it could get a bit pricey to reinstall.
81 Targa, Bamboo Beige, 3.2 SS |
Nice commission!
Hope the sweater went with the 944! JK! Welcome and enjoy!! Carter |
Undocumented User
Good place to start, but I'd save the money on the Swepco and the Wevo and just go for some Kendal Hypoid gear oil at about 1/4 the cost and the coupler whisperer's inserts at about 1/4 the cost as well. Maybe check out the tranny and motor mounts as well.
Congrats. Nice looking rig. Enjoy! d
DIY injector cleaning
Congratulations on your new 911 Mike. If you want to try cleaning your injectors yourself, take a look at Billjam's DIY in post #12 in this thread and welcome to the forum!
Blocked Injectors - how to clean?
'82 SC cabriolet |
AutoBahned
I would just send them out - places will do flow testing on them too.
Be sure to replace your rubber brake hoses with new; repl. old rubber fuel hoses with pressure rated EtOH rated new hose and change all fluids. Then enjoy the car. |
welcome to the board, targa & whale tail is a nice combo, enjoy!
82 SC Targa Guards Red = Toy 04 E55 AMG Brilliant Silver = DD 04 Cayenne Turbo Platinum Grey on 22s = Previous DD 80 Wide body 12AT RX7 Black 350+ hp= Previous Toy 78 Alfa Romeo GTV Blue = My 1st Cool Car |
Thanks for the warm welcome and advice. Looking forward to learning from everyone who has "been there, done that"
durn for'ner
Welcome!
Markus Resident Fluffer Carrera '85 |
Fb = M/S
I have an 81 911SC US coupe. Things to watch are the oil return tube seals, clutch cable, CIS issues - you'll find a bunch of stuff here on all of these items.
Your original AC compressor was a York - mine has never worked well, and I would consider getting a newer compressor along with some barrier hoses. Do a search on keuhl and get some advice on what you need to replace your AC. |
Coram Deo
Welcome! My '80 Targa has more brethren here now.
![]() Expect to fiddle with CIS, replace the oxygen sensor relay, and struggle with a few other niggles. Expect lots of good help, and expect to feel lots of satisfaction when you've successfully solved them.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Congratulations! You can't beat an SC for the perfect blend of style, reliability, performance, and awesome factor.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Ac
I am not sure about the amount of AC compnents present. I will take a look. At the moment I am dealing with an alternator not charging the battery. The light is not on which is a bit confusing. Any ideas? Thanks!
welcome. you will find alot of nice people here with alot of good info.
Id take the car to sears and have them to a charging system test. It will test the battery, alternator, regulator, and starter as well as test for a drain. They do it under load and not. Cost less than $20. you could do it all yourself with a meter and a few hours but on some of these things a good baseline is helpful and just easier...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Never even thought of that. I will check it out.
I don't have an SC, but I do have a targa -- the more you keep the top off the more you will enjoy your car. My top has been riding around for around 368k miles in the front trunk. Don't worry too much about the A/C, the stock stuff is junk anyway - get an aftermarket R134kit and you'll be miles ahead. The dismantlers like Parts Heaven can get you other stuff like blower motor housings etc if these are missing. Chuck.H '89 TurboLookTarga, 369k miles |
Thanks Chuck! I'll check the bulb
![]() Quote:
