-   -   passenger side window issue (http://forums.pelicanparts.com/porsche-911-technical-forum/785062-passenger-side-window-issue.html)
pensacola mike 12-02-2013 04:52 PM
I'm having an issue with my passenger side window. I can hear the motor moving inside the door, but it is like the window has lost grip or something. I can manually push the window down inside the track after I have pushed on the window regulator to try and lower it. I'm not concerned with it being stuck all the way down because I can also raise the window with out any problems it just wont go down. I would appreciate some insight!
pors1968 12-02-2013 05:27 PM
the arm of the window regulator is of track or broken or the gear is strip.
