-   -   alignment camber adjuster tool question (http://forums.pelicanparts.com/porsche-911-technical-forum/785575-alignment-camber-adjuster-tool-question.html)
kodioneill 12-05-2013 11:12 AM
What size allen is used on the rear camber / toe adjusters? Anyone have a tool design that works easiest?
john walker's workshop 12-05-2013 12:54 PM
i just cut a couple of short pieces of 12mm allen stock, about 1/2" long and tigged them to a 12" flat bar. one on each side of the tip, clocking the flat on one side 1/2 way between the flat of the other side, so if you run out of swing, just flip it over and continue. the stick out of the bits are just long enough to bottom out in the adjuster, being you have limited room.
