kodioneill's Avatar
alignment camber adjuster tool question
What size allen is used on the rear camber / toe adjusters? Anyone have a tool design that works easiest?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-05-2013, 11:12 AM
i just cut a couple of short pieces of 12mm allen stock, about 1/2" long and tigged them to a 12" flat bar. one on each side of the tip, clocking the flat on one side 1/2 way between the flat of the other side, so if you run out of swing, just flip it over and continue. the stick out of the bits are just long enough to bottom out in the adjuster, being you have limited room.
206 637 4071
Old 12-05-2013, 12:54 PM
