JoeFic's Avatar
Light fixture under engine with missing bulb
Hi guys,
Working on my 1985 3.2 Carrera and found a fixture just above the engine on the lid with no bulb in it...
Any ideas as to what type of bulb belongs in there?
It's an odd looking thing and I've searched for threads and posts to attempt finding out what belongs in the fixture...
Thanks in advance for any help you can share!
Joe
Old 09-06-2013, 03:27 PM
Rescuer of old cars
Arne2's Avatar
Engine compartment lamp. Only works when the lights are on. I suspect it uses the same bulb as the interior dome lights, but don't quote me on that.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 09-06-2013, 03:36 PM
JoeFic's Avatar
Thanks Arne - it's a good idea, and I tried that but apparently it's longer and bigger in diameter, looks a tad smaller than a C-size battery...
Old 09-06-2013, 05:36 PM
JoeFic's Avatar
Got it !
I did a search of our host Pelican for Engine Compartment Lamp - Voila! There it is for only $1.25
Old 09-06-2013, 05:43 PM
Go-Kart Mozart
JAR0023's Avatar
It's called a festoon bulb. Turns on and off as you slide the cover open. As Arne said need to have at least the park lights on. Took me months to figure that one out. Probably as big around as an AA battery. Measure between the contacts to get approximate length. You could also check your owner's manual for the size. -J
ETA:
Pelican Parts - Product Information: 900-631-106-90-M97
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-06-2013, 05:47 PM
It's a 37mm festoon bulb.
Old 09-06-2013, 07:33 PM
wrxnofx's Avatar
If yours was like mine, it's been a while since it has worked. Therefore, you might find that you must clean the contacts to get it to work. It's easy to do this.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 09-06-2013, 08:28 PM
JoeFic's Avatar
ETA:
Thanks Guys! The part is on it's way...
As soon as I get the bulb I will replace and post some pics...
Old 09-09-2013, 07:46 AM
muck-raker
kidrock's Avatar
be careful if you need to work on the engine lid fixture, the wires can be very dirty and brittle. You'll know if something's messed up when you put things back together and find out that your driver's side parking lamps and tail lights no longer operate. Ask me how I know.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-09-2013, 07:52 AM
JoeFic's Avatar
Ok so I just ran down into the garage and checked voltage and there's nothing at the fixture and oh by the way I noticed that the interior light on the targa bar isn't working either! But the driver's side parking lamp and tali lights still work!
Old 09-09-2013, 08:06 AM
Troll Hunter
I noticed my engine bay light not working also. Then I noticed there was no wire running from the switch to the fixture...doh!
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-09-2013, 08:15 AM
86FlatSix
JQ911's Avatar
Engine compartment lamp/light fixture on a ducktail?
Not sure if I make sense which in most cases I don't. I am in the process of having my Stratton ducktail painted. I do not recall the ducktail having the bar or thingy where you mount the engine compartment/light fixture which is present on the factory tail. Has anybody tackled this issue? Did you guys just delete the engine compartment lamp or you just relocated it elsewhere? I don't even know if the ducktails came with a light on the engine compartment.
To tell you honestly, its been a year and a half since i bought the car and never figured out if that light was working.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 12-04-2013, 04:15 PM
pors1968's Avatar
It work whith parking light on When you slide the cover it ground contact most time you have clean the contact.
Old 12-04-2013, 07:21 PM
The black cover snaps on/off. Pull it off and you can see the contacts on the driver side. The silver sliding cover has to be all the way open for the contact to make and the light to come on. My problem was that someone had put the black cover on backward. It is not symmetrical and has to be snapped on in the correct orientation to allow the silver sliding cover to go all the way open and make the contact. I believe the bulb is the same as the glove compartment bulb and interior lamp bulb (and most likely the luggage compartment light bulb, though I have not tested that.)
1987 911 Targa, Guards Red/Champaigne
1969 Porsche 912 (1972 - 2013)
2004 Ford Focus SVT Euro
Old 12-04-2013, 08:37 PM
wrxnofx's Avatar
The luggage compartment bulb on my '87 is different than the engine compartment and dome lights. The luggage compartment one is a "conventional" bulb, 10W if memory serves.
Old 12-04-2013, 09:30 PM
where is the engine compartment light mounted...anyone have a photo?
Old 12-07-2013, 06:18 AM
This on a '82 SC
Carter
Old 12-07-2013, 09:18 AM
86FlatSix
JQ911's Avatar
I replaced my factory whale with a duck tail. The duck did not have the metal bar that lines up to the latch where the light fixture is mounted. So I fabricated a bracket so I can still put the light fixture. What do you guys think?
Old 12-07-2013, 05:03 PM
911 Besitzer
Looks like a pretty clever solution!
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 12-07-2013, 06:19 PM
